Antenna broken
Old Jul 14, 2011 | 01:48 AM
Born2cure's Avatar
Born2cure
Default Antenna broken
Someone came by and decided to snap off my antenna. Broke the bolt, guess ***** to cheap to pay $12 to buy their own. Do I have to pull light bar off to replace. Couldn't find in manual.
Old Jul 14, 2011 | 05:58 AM
stuart1270's Avatar
stuart1270
You don't have to remove the light bar. Best to remove liner then small nut . the screw is a threaded rod type remove it then pull the antenna stub up. cost about $7.00. By the way if you ride 2 up and rode off with the lid open it breaks off very easy.
Old Jul 14, 2011 | 11:14 PM
Born2cure's Avatar
Born2cure
Thanks stuart, hope that's what happened hate to think a fellow rider would do it. Tried it has an Allen head but is so tight wondering before I force it it's not reversed threaded is it.. Do appreciate your reply.
Old Jul 14, 2011 | 11:40 PM
vzts4q's Avatar
vzts4q
nope its a standard thread, you do have the lock nut off already don't you.
Sounds like the the part you need is a 76260-89 this is item 14 on the following instructions.
http://www.harley-davidson.com/en_US...ts/-J03791.pdf
After you get the screw out you will probably have to use a pick or something to pry the stub up enough to get it out. This is assuming just the threaded end is what broke off.
The follow instructions give a better picture on how the pieces go together even though they are for the LED light set-up.
http://www.harley-davidson.com/en_US...ts/-J05090.pdf
Old Jul 19, 2011 | 12:57 AM
Born2cure's Avatar
Born2cure
Thanks guys! VZTS4Q the info you posted gave me the courage to use vice grips to get bolt out. The Allen wrentch kept slipping and twisting. Got it out thanks for the time and effort.
again thank you
Old Jun 6, 2014 | 02:33 PM
Jody Honeycutt's Avatar
Jody Honeycutt
Stage III
This was extremely helpful, and proved me right in the process. My hubby thought we had to take off the whole light bar assembly. I told him that I didn't think we would. I was right! WooHoo! LOL
Old Jun 6, 2014 | 05:53 PM
Lowcountry Joe's Avatar
Lowcountry Joe
You can find used antennas on eBay if interested.
slowrollin
2014-2024 Touring Models
Jun 17, 2025 01:21 AM
voudoujoe
Oct 1, 2024 07:34 PM
LQQK_OUT
General Topics/Tech Tips
16
Dec 26, 2017 04:44 PM
digdug
Jul 11, 2014 11:44 AM
Sporty302
Aug 1, 2011 04:39 PM
