starting problems 03 elctra glide
Old Jul 18, 2011 | 09:36 AM
VINNIE JAMES's Avatar
VINNIE JAMES
Default starting problems 03 elctra glide
i had to weld a broken exhaust pipe and brackets on 7/12. it did not start right up when i was done. did not think twice...no big deal. started on the 2nd time.
over the weekend it took 3 or 4 times to get it started. not sure if its not getting fuel? also sometimes when i crack open the throttle it stutters. dont have the money to take it to the dealer...and my friends have no idea? i ride every day. any ideas?
i would also like to post a video of how it sounds when it does not start. can i do that on the hdforum? this way you guys might be able to help me better. thanks,vinnie
Attached Thumbnails starting problems 03 elctra glide-imag0369.jpg   starting problems 03 elctra glide-imag0368.jpg   starting problems 03 elctra glide-imag0374.jpg   starting problems 03 elctra glide-imag0376.jpg
Old Jul 18, 2011 | 10:14 AM
speakerfritz's Avatar
speakerfritz
if you know anyone that can do some welding for you....you can insert a sleeve inside the pipe and then weld the two pipe pieces to it.
Old Jul 18, 2011 | 11:02 AM
VINNIE JAMES
sorry. all the welding is done. bike is together and running. im having starting problems
Old Jul 18, 2011 | 11:06 AM
VINNIE JAMES
i just went out on my bike. it started right up. stopped by a deli and it did not want to start...stopped for fuel...it did not want to start again. when i got back home. i shut the bike off. looked it over. went to start it AND NO problem???? wtf??? i have no idea what is going on??? need help. thanks, vinnie
Old Jul 18, 2011 | 11:10 AM
Panhead Bill's Avatar
Panhead Bill
[quote=VINNIE JAMES;8585757]over the weekend it took 3 or 4 times to get it started. not sure if its not getting fuel? also sometimes when i crack open the throttle it stutters. dont have the money to take it to the dealer...and my friends have no idea? i ride every day. any ideas?
Is the bike injected or carb?
Old Jul 18, 2011 | 11:11 AM
VINNIE JAMES
injected
Old Jul 18, 2011 | 11:31 AM
Panhead Bill
Originally Posted by VINNIE JAMES
injected
I had a similar problem on my 06. The quick disconnect on the fuel line where it goes into the tank wasn't fully snapped onto place. Try pushing the collar up and removing the fuel line and clean under the collar with some electrical parts cleaner. Got a bunch of dirt out of mine. Then snap the line back in, it in there and spin the collar around and make sure it is locked fully in.
Old Jul 18, 2011 | 11:50 AM
ironhead3fan's Avatar
ironhead3fan
Does it do nothing, or just not fire? Mine is starting to just do nothing on occasion. I am going to tear into it soon. My wrench told me to undo the starter where the 3 screws hold it on. Pull out the rod and clean off the brushes with emery paper. Could also be the relay under the seat as well.
Old Jul 18, 2011 | 03:29 PM
VINNIE JAMES
it sounds like its not getting fuel...and then it sounds like the starter is spinning...and coughs thru the air cleaner. on the second try. it catches...but its random?
Old Jul 19, 2011 | 03:08 PM
VINNIE JAMES
my bike started up 3xs today with no problems...the dealer has no idea what it could be?
