Cam Dot Alignment
Old Jul 26, 2011 | 12:17 PM
iclick's Avatar
iclick
Originally Posted by boogaloodude
I remember all the trouble you had with the mis-marked timing dots on your 255 cams. That would be frustrating as hell, especially once you've redone your work, double checked everything, discovered a manufacturing defect where the timing dot was improperly marked, and it still didn't fix the problem.
I remember that debacle too, and I hold Sickbagger's efforts high on my list of notable diagnostic achievements. OTOH I thought he fixed the problem and the cams proved functionally perfect once he got the timing figured out. I wonder how many more of those problematic cams are floating around out there. They did issue a Tech Tip (TT296) in March 2007, so that being four years ago should make the possibility of getting another one very low. You'd think most were probably caught by HD dealer service techs and we can only hope most or all of those defective cams have been pulled from circulation. OTOH I would certainly check if I bought a used set.
Old Jul 26, 2011 | 08:36 PM
rm4040's Avatar
rm4040
Thanks all for the input. It was one tooth off, I guess that is what happens when you don't pay attention. There is a major difference in performance.
Eastcoast Jim
Engine Mechanical Topics
Sep 13, 2016 08:41 AM
Wmitz
May 17, 2014 08:47 PM
trnewman
Apr 25, 2013 07:31 PM
freefallvnvlv
Mar 30, 2012 03:28 PM
Sallyman
Jul 8, 2010 09:20 PM
