Just installed 255 cams. I thought I made sure dots on cam gear lined up but now I am not so sure. Bike starts and there is quite a bit of lope( forum responses state there is not much lope with the 255 cam}, the exhaust sounds different at low RPM's and it seems to run hotter. Bike seems to run okay while acclerating, but just seems much different than stock.
Question is what are the symtoms if the dots are one tooth off?
You are on the right track. Compression test is the best way to tell. I actually did this on my first cam install. Compression test showed 190 front and 110 rear.
Bike also did not run well and had a major hesitation off idle until about 2500 rpm.
Your right check tge compression that will tell. Bith the dots on the cams and tge dits on the sprockets have to line up. Cams use the inner chain the sprckets use the outer chain.
I had the dealer install 255's on my UC early spring and they had the same exact problem. Turns out he found 2 dots on the cams. I'm no where near a mechanic, so please bear with me . . .
He showed me what occured and I will try to describe what I saw. I saw one set of dots were on the end of the shaft (he said this is where the dots are normally). There were however ANOTHER sets of dots on the sprockets.
He first lined up the dots on the end of the shafts (which he said was normal procedure). When they took it for a ride, he said the UC backfired, ran rough, and generally had all sorts of running problems (including running hot). It ran so hot that the V&H slipon for the rear cylinder (true duals) turned gold and was starting to turn blue.
He got on the phone with HD and after some lengthy conversations, HD had the shop line up the dots on the sprockets!
This cleared the problem . . . except for them to fix what had been damaged (the slipons).
If you are going to have them program the EI, make sure you ride it and not them as your shift points will differ greatly from whomever takes it for the spin. Again, I found this out the hard way (I rarely exceed 3000RPM) and had them redo the tune with me as the rider. I saw the map afterwords and it sure changed from what they first tuned it as (low range for me vs. a much higher range they placed on it).
Also, have the shop check your clutch for adjustment. Had to have my re-adjusted after the 255's because of slippage . . .
I had the dealer install 255's on my UC early spring and they had the same exact problem. Turns out he found 2 dots on the cams. I'm no where near a mechanic, so please bear with me.
Of course it cleared-up the problem, as he did it right the second time. His explanation was a long-winded but lame excuse for doing it wrong, as the two sets of dots on the cams line up the same and he simply didn't align them correctly the first time. This is checked while inserting the cams into the chain using the dots on the sprockets, and again to double-check after it's all assembled in the cam plate from the outside, which is the reason for the second pair of dots. It's a simple procedure that he screwed up by carelessness, and I'm sure HD gave him an earful when he talked with them. If they didn't they should have.
You hear about alignment errors all the time, but I don't understand how so many people manage to do it wrong. It's really very simple if you use due care during assembly. [/lecture]
I remember all the trouble you had with the mis-marked timing dots on your 255 cams. That would be frustrating as hell, especially once you've redone your work, double checked everything, discovered a manufacturing defect where the timing dot was improperly marked, and it still didn't fix the problem.
That was a crazy problem that had a lot of smart people vexed, and it's a good thread to read. Sometimes you have to re-do your work more than once to get a problem fixed.
