bad lifter????
Old Jul 28, 2011 | 08:49 PM
djl's Avatar
djl
Originally Posted by Jinks
Pull the lifters. Try to move the rollers with your fingers (no, don't roll 'em, move 'em side to side/up & down) if you can move 'em, they're bad. Replace all of 'em with new. Check the cam chest for debris.
Also good advice.
Old Jul 29, 2011 | 09:10 AM
harleydavidone's Avatar
harleydavidone
I talked to Jamie @ FM and he said a lot of times you cannot tell the lifter is bad by looking at them so I am going to take the guessing out and buy the woods lifters and be done with it. I am not sure if I will stay with the FM push rods yet as they are locktited in and they are really kind of a pain to work with. I may just switch to the SE tapered as it seems like reading here a lot of people have had good luck with them. I think I read somewhere here that Bob Woods had recommended a different setting than the stock turns though???? Has anyone seen this????
Old Jul 29, 2011 | 11:45 AM
djl's Avatar
djl
Good move. Woods recommends that pushrods be adjusted to .120"-.130" of lifter travel. The SE Tapered pushrod instrutions are 2.5 turns which would be about .100" of lifter travel. So, 3 to 3.5 turns should get you there; instructions are included.
Woods lifters come primed with a light oil and the ones I have done bled down quickly but I have some have posted that they had to wait a long time for the lifters to bleed down; don't know why.
Old Jul 29, 2011 | 02:24 PM
CURTYS06FLHX's Avatar
CURTYS06FLHX
Thanks for the info djl. That was good information.
Old Jul 29, 2011 | 02:52 PM
harleydavidone
[quote=djl;8631462]Good move. Woods recommends that pushrods be adjusted to .120"-.130" of lifter travel. The SE Tapered pushrod instrutions are 2.5 turns which would be about .100" of lifter travel. So, 3 to 3.5 turns should get you there; instructions are included.
So the SE's must be 24tpi, that would make 3 1/4 turns right in the mean (.125"), I ordered the Woods Lifters today and Keith said with the FM rods go 4 turns, they must be 32 tpi.......... if I remember correct I used 3 turns & 1 flat with the stock lifters?
He said it only takes an extra 1/2 hour to pull the tank & come in from the top to remove the pushrods, so you can remove them whole & undue the locktited nuts. I am still up in the air on this, for the cost of new SE's & the hassle of the locktite, I just may get the bolt cutters out!!!
Old Jul 29, 2011 | 03:06 PM
djl's Avatar
djl
A word of caution. Smith Brother's recommends the judicial use of loctite on the locking adjustor nuts for their tapered "quick install" (not) pushrods. Based on the experience I and some others have had with the SE tapered units, I strongly suggest that you apply a dot or two of loctite to the locking adjustor before locking her down. Once the adjustment is complete, I back the adjustor nut off enough to give me room to use a toothpick and place a dot of red on the thread just below the pushrod flat that the adjustor locks up against and another dot on the face of the adjustor nut and that same flat. The lcotite provides a little more secure lock but there isn't enough to make re-adjustment a PITA.
I never did that before but after having an SE adjsutor come loose, I figured if Smith Brothers is recommending loctite, it might not be a bad idea.
Old Jul 29, 2011 | 03:21 PM
uscanuck's Avatar
uscanuck
How much locktite did you put on these pushrods? Not sure I would use bolt cutters on something that cost $150...
I've got a set of these and when I replace the lifters this winter I'll likely just get a set of the longer (at the bottom) pushrod covers. Even with the little holder that comes with the FM rods there is very little room when using the stock covers. I had to grind down the width on one of my wrenches so that I could use it on the top nut while tightening the lock nut to it.
Old Jul 29, 2011 | 03:25 PM
Stiggy's Avatar
Stiggy
I had one of the "old" style S/E pushrods come loose 8 miles from the house and limped it home. Surprised me to find that in that short amount if time, the nut had come completely off and was later found in the cam chest.
Re-installed with a drop of blue loctite, ( what I had at the time,) and still carry 3 wrenches just in case. So far so good.
And I run my Black Ops lifters at about .140."
Old Aug 1, 2011 | 04:01 PM
harleydavidone
Well I ordered the woods lifters Friday morning from FM and they arrived Saturday morning, one of the local dealers was having a sale so I bought the SE prem. tapered pushrods and tore into it. Was just going to take the lifter covers off and come into the top until the little dowel that clocks the lifters fell into the cam case, so off came the exaust and cam cover. I figured while I was in there I would re-adjust the oil pump because there seemed to be more oil in the case than I thought there should be, so Saturday tear down and Sunday build back up and everything is back to normal! The old lifters looked fine, the FM push rods looked fine, but they were both replaced and no more noise..............
Old Mar 24, 2013 | 06:34 PM
Cosmo13's Avatar
Cosmo13
6th Gear
Default SBC lifters
Hey ya'll new to this forum (new member) but been doing a "LOT" of reading on this H-D lifter threads. First off, I'm running a 95 ci 02 Road King with S&S gear driven cams (585G), did that after 6K on the new motor, rear cam shoe came undone, so riding Shovels and Pans and Sportsters over the years, gear whine no big deal. When we did the build back in late 02, we thought we did it right, even installed a S&S breather valve, to stop the oil blow by. Ran SE tapered adjustable pushrods, SE performance valve springs, SE rocker support plates, SE rolling rockers, and "SE performance lifters". Always using Amsoil 20W-50. That's the history until around 40K, then came the CLICKING NOISE FROM HELL. As we got into it we had found that the "SE performance lifters" had failed, got lucky and could account for all the needle bearings, but the lifters were shot and no real damage to the cams. John my machinist buddy (everyone should have one) told me that the SE stuff was junk and that I should install the H-D B's. Went to the shop, Harley changed them to C's, so C's it was. All seemed well until a little road trip to Daytona (little over 66K now). Front cylinder started doing the click click noise until it got warmed up then it was good again, but it seemed to be getting worse with each gas stop. So after doing A LOT OF READING on this lifter subject. There are a lot of guys out there on a lot of different forums that share some damn good information. I ended up going to the local Chevy dealer and buying two AC-Delco ACD# HL 124 SBC lifters or GM part#17122490, installed just the two and currently have 70,208 miles on the motor and no problems, no clicking. So I thought I would share and hopefully this will help. Down the road........FAST!
