2011 103 engine knocking?
Old Sep 4, 2011 | 12:03 PM
bohica48's Avatar
bohica48
What got my attention was "and can hear plain as day when sits for 15 minutes", are you saying it is idling for 15 minutes then you start hearing it?
I seem to remember this issue came up 10 years ago and was discussed at length, basically saying these engines are not designed to sit and idle and will make strange noises when that happens. I had a Softail at the time, started mine one morning to go ride, got sidetracked for a few minutes and it started knocking, never had a problem with it for the next 4 years when I sold it.
I'm not doubting what you are hearing and it could be something unrelated to my comments but I thought I would throw it out anyway. I wish you the best in what ever you decide to do.
Old Sep 4, 2011 | 12:08 PM
Bluetoys's Avatar
Bluetoys
If it is idling for 15 minutes, I almost bet it is going into parade mode, or whatever it's called when it only runs on one cylinder when it gets too hot.
Old Sep 4, 2011 | 12:16 PM
NDBadlands4-2's Avatar
NDBadlands4-2
I have a 2012 with 4500 miles on it. No noises as yet. Yours has to be still under warranty. I would just take it in to the dealer. At least get it documented so that if there is an issue after the warranty expires, you can say the problem started while the warranty was still valid.
Old Sep 4, 2011 | 12:35 PM
DannyZ71's Avatar
DannyZ71
Originally Posted by ringer19
i have so many issues with this bike in the last 2 months , sick and tired of it . told them to do the math on a new 2012
That's a shame. But that's exactly what the dealership wants you to do.
Old Feb 10, 2012 | 01:05 PM
AndyinTally's Avatar
AndyinTally
Default At wits end!!!
Originally Posted by Bfazona
I see you have some mods done, are you sure that it's not spark knock? My '11 didn't do it until I added cams, then I'd get terrible knock. It's a timing issue and sounds like small rocks hitting your fender.
Mine started with the knock at around 1800 miles, right after i had the selling dealer do a dyno on it. Unfortiunately I bought my bike from a dealer 200 miles away so I now had to take it to the local dealer. I told them about the knock and they seemed to not be to interested or give it too much interest. They said they believed it might be the throttle body. At that time i was ready for a cam upgrade and had that dealer install the Andrews 37h. When I picked up the bike, the knock was much more pronounced and again they said it was probably the throttle body and told me to call them the following week as they were talking with the factory to discuss the issue with them. I brought it back the following week and asked them to please take another look/listen to the knock as I was concerned. Once they heard it again, they asked me to leave the bike and now its been over a week and all I get from them is that they are talking with the factory rep and doing tests but have yet to determine the cause. I think 9 days is exsesive for them not to have a solution. I am at wits end!
Old Feb 10, 2012 | 01:13 PM
djl's Avatar
djl
Originally Posted by 07FLHT
Whats the easy way to check if its the compensator? I have some noise too sence changing over to th SE compensator & would like to make sure thats all it is. Thanks
If the compensator is making noise, it is because it is loose. You would need to pull the outer primary cover and check the torque on the comp nut.
Old Feb 10, 2012 | 01:36 PM
Bluehighways's Avatar
Bluehighways
Throttle Body? Wow, is that ever a bunch of BS if I ever heard any. I wouldn't let that mechanic change my oil. Man is that a sign of incompetence!
A Rod or Main Bearing Knock will not change all that much with Engine Temperature or Engine running time. Once a Rod or Main Bearing starts to fail it will not go away; and engine life will be extremely short (minutes or maybe an hour if you are really lucky) from that point on. But it will definitely get louder when you apply a load to the engine.
Valve Train Noise, particularly a Hydraulic Valve Lifter problem can change with Engine Temperature and Oil Pressure. It can set up quite a racket. But while this noise will change in frequency in direct proportion to Engine RPM it will not change with the load on the engine.
For the really curious, take off the Oil Filter, Cut it Open with a filter opener or a Pipe Cutter that is large enough for the diameter of the oil filter (Harbor Freight) Do NOT use a saw. Anyhow, cut it open as close to the base of the filter as possible and remove the Filter Element. Now cut that open, with a Knife (not a saw). If you've got something serious coming apart in the engine there will be a significant amount of metal shavings in there. Do NOT use a saw to cut open any of the Filter as the metal shavings from the saw blade will give you a heart attack even though there may be nothing wrong with your engine.
Old Feb 10, 2012 | 01:58 PM
Dewky's Avatar
Dewky
I would really doubt that the conrod bearings are a problem, most likely the compensator causing that knock.
dewky
Old Feb 16, 2012 | 06:10 AM
AndyinTally
It's been in the shop 2 weeks now and they have checked heads, pistons, and who knows what else. The dealer has had the MOCO rep look/listen to the bike. His latest suggestion; change out the push rods. No change. Knock continues. Nothing happens unless they get some sort of approval from the MOCO rep. I asked to have a meeting with the rep and the service guy at dealer said rep would not meet with me because it was not company policy to meet with customers.
Now dealer says the reason its taking so long to do anything is that they need to run everything through MOCO because my bike was put on a "blacklist" as a result of having a race tuner installed at the dealer at the time of purchase!!!! Is this for real???? Not only does the MOCO manufactor this stuff, the dealer pushes you to buy it, they install it, then put you on a "blacklist" and refuse to stand by thier product. This is insane!!!
Old Feb 16, 2012 | 07:07 AM
btsom's Avatar
btsom
Time to start looking into your state lemon laws. Go in with a list of the criteria this case meets so far and you may get their attention.
