V&H throttlepac
Old Jul 31, 2011 | 11:03 AM
PLEIKU69's Avatar
PLEIKU69
Default V&H throttlepac
Anyone tried this on the throttle by wire bikes and if so did it work?
Old Jul 31, 2011 | 11:09 AM
HDV-GLIDE's Avatar
HDV-GLIDE
try the search function on previous posts on the throttle pak......yes, it works.....
Old Jul 31, 2011 | 12:05 PM
XARAN's Avatar
XARAN
Im told the throttle lag can be programed out with a TTS, SESPT or PCV so theire is not a need for it. If you are using the fuel Pak it doesnt allow the adjustment
Old Jul 31, 2011 | 12:38 PM
SE120RG's Avatar
SE120RG
you can tune it out on the SESPT and the TTS, not sure about the PCV. I tried one out for a weekend to see if it made any difference on my bike with the SESPT. I did not notice any difference with it on and I went out for a ride and bike through the same routine with it plugged in and without. If your running a stock bike or another type of tuner your results may be different
Old Jul 31, 2011 | 01:17 PM
07flhxrider's Avatar
07flhxrider
i worked with chris @ cycle solutions over the weekend and it works very well.. if you havent purchased a programmer i would highly recommend the zipper thunder max for a programmer.
Gunnysgt
13
Mar 28, 2012 12:00 PM
Rickr01
Aug 10, 2011 01:40 PM
Canuckle
Jun 8, 2011 02:19 PM
Charkit
Mar 12, 2010 05:58 PM
RODEO
Feb 15, 2009 11:26 PM
