Clutch
Old Aug 1, 2011 | 11:14 AM
SteelCityRider's Avatar
SteelCityRider
Default Clutch
Finally got time to finish my bar install, started and check all buttons, works great. Put new clutch cable on, here is the problem, with clutch in, put in 1st gear and bike started going, while holding the clutch in. I have the manual but with the storms we had, my garage leaked and my book got a little wet. Pages are still stuck together. Might it be the adjustment or do I have to take the cover back off and check inside?
Old Aug 1, 2011 | 12:11 PM
Bleachey's Avatar
Bleachey
I would suggest adjusting it. Mine was doing a similar thing and adjusting helped. My bike is older, a 1996, but my manual said you had to adjust both the cable and in the primary access cover. It wasn't that hard to do, make sure you find out the steps to take. Mine took about 15 mins, loosened the cable fully, loosened the lock nut, loosened the adjusting screw, then went back in with the tighteneing screw until I met resistance, backed it out a half turn, locked it down then adjusted the cable. It got rid of the "tugging" when stopped.
Old Aug 1, 2011 | 01:57 PM
SteelCityRider
Thks, hop it works. I did not want to take the cover off again. Guess I might have to.
Comfortably Numb
May 3, 2021 12:45 AM
Bulldog1085
Shovelhead
11
May 2, 2019 11:22 AM
HWill
Feb 24, 2013 09:26 PM
AK47
Mar 19, 2009 10:18 AM
jpowell490
Mar 17, 2008 06:17 PM
