My trim rings whistle
Old Aug 2, 2011 | 05:15 AM
skully1200's Avatar
skully1200
Default My trim rings whistle
I put trim rings on my headlight and passing lamps of my road king. The wind whistles through them. Not sure which one(s) specifically. Kind of annoying. The passing lamp rings have foam weather strip type stuff in them but not the headlight. Any ideas?
Old Aug 2, 2011 | 07:13 AM
Red9's Avatar
Red9
I know this isn't what you are looking for but I have to ask...
Have you had any problems with deer?
Old Aug 2, 2011 | 11:27 AM
skully1200's Avatar
skully1200
No, not yet, knock on wood
Old Aug 2, 2011 | 11:36 AM
MrHog's Avatar
MrHog
I had the same issue. The headlamp nacelle trim ring was the culprit. Took it off and never put it back on. Left the passing rings on and no whistle.
Old Aug 2, 2011 | 11:48 AM
mkguitar's Avatar
mkguitar
I'd maybe try some rtv silicone, something that'll seal, but not prevent removal
figure the whistle is from air moving under it, esp. at the screw
Mike
Old Aug 2, 2011 | 12:01 PM
HessKC's Avatar
HessKC
2nd Gear
the air flowing through is causing the whistle, you might try some of the thin foam that is used to seal exterior doors, you can find it at lowes, home depot or sometimes even wall-mart
Old Aug 2, 2011 | 01:13 PM
bbflhrs's Avatar
bbflhrs
I had the same problem. The wind rushing through the split at the attachment point. I got some 3/8 "backer rod" grey foam at Lowes and that fixed it. I like the way the trim piece looks but it is a chicken $h!t design if you ask me.
Old Aug 2, 2011 | 01:50 PM
Poochie's Avatar
Poochie
definitely a bad design, although I never left mine on long enough to whistle. after fighting with it to keep the sides tight against the nacelle i finally threw it as far as I could. i've got the visor rings on the passing lamps and turns, but left the headlight as is...no whistle.
Old Aug 2, 2011 | 02:13 PM
Baffler1's Avatar
Baffler1
are there any attractive women around when the whistling occurs - if so problem identified -
bman7163
2014-2024 Touring Models
Feb 17, 2018 09:10 AM
btharris24
Feb 17, 2016 01:48 PM
Bobby12012
Oct 22, 2014 02:11 PM
SoonerSoftail
Feb 24, 2011 08:18 AM
shagnasty
Feb 21, 2010 09:47 PM
