Air suspension adjustment
Old Aug 3, 2011 | 04:07 PM
horseplay's Avatar
horseplay
Default Air suspension adjustment
New to the HD world but we ride with a couple that have been on Harley's for years. Last weekend after we picked up our bike I borrowed my buddy's air pump and proceeded to pump up the air ride, it would only take 25 psi. We tried it on his 2006 Electra Glide classic and it would pump up to 30psi. I have read on my 2010 for 2 up (and we aint small people) I should put it at 50? But it only takes 25? Thinking this is something I might get the dealer to check along with the constantly on ABS light since I picked up the bike.
Old Aug 3, 2011 | 04:12 PM
Navyrep1's Avatar
Navyrep1
Constantly "on" ABS light would be my biggest concern....likely means it ain't working. Have them check out your suspension while you're there.
My '02 maxs out at 20 psi, but they changed shocks and raised the psi limit on later year bikes. Mine rides best at about 6 psi but that isn't a fair comparison.
Bring it in for the ABS, get the suspension question answered as a bonus.
Old Aug 3, 2011 | 04:28 PM
jeff.georgalas's Avatar
jeff.georgalas
Yup, you're still under warranty. Have them look at both the ABS and the shocks. Your pressure problem doesn't make sense to me. You should be able to put in as much air as you need.
Old Aug 3, 2011 | 04:51 PM
mllgator's Avatar
mllgator
As before, Have the ABS checked & pronto.
While you are there, try a new pump. Your buddies may be damaged.
Also pump it up and bleed the pressure down to where you want it.
Old Aug 3, 2011 | 06:20 PM
K Melancon's Avatar
K Melancon
Question - Does his pump go to 60 PSI or only 30 PSI ?????? They make different pumps and they all look alike.
Old Aug 3, 2011 | 08:20 PM
horseplay's Avatar
horseplay
His pump went to 60. We tested his pump on his bike and it pumped his up fine!
Dropping the bike off on Sunday to get these items checked out!
Old Aug 3, 2011 | 10:49 PM
JonW's Avatar
JonW
Actually, you should bleed the air down and then pump it up to where you want it. Puts any remaining oil in the pump back into the system.
Old Aug 3, 2011 | 11:06 PM
mkguitar's Avatar
mkguitar
careful you don't over pressure the system.
your manual will give suggested settings, as will the sticker on the crashbar
You are using the little 'syringe" type pump?
Bicycle pumps can cause damage.
BTW my 09 rides best with 7 to 10 pounds solo/2 up
Mike
Old Aug 4, 2011 | 02:58 AM
av ultra's Avatar
av ultra
My 10 is pretty comfortable on the freeway solo at 18 and 46 two up, om at 180 and ol at 130
Old Aug 4, 2011 | 04:51 PM
Guitar4Him's Avatar
Guitar4Him
I run 50 lbs in mine. It gives the best ride with 2-up and handles better in the twisties solo. Plus...I weigh 260...
