Shift linkage hitting back if primary
Old Aug 4, 2011 | 08:14 PM
Theride's Avatar
Theride
Stage IV
Default Shift linkage hitting back if primary
I have a '96 FLHT, I have two issues.
1- the shift linkage is hitting the back of the primary and gouging it pretty good.
2- it's tough finding neutral
Any ideas what may be going on?
Thanks
Old Aug 4, 2011 | 08:34 PM
Fast Aire's Avatar
Fast Aire
Former Sponsor
Either the trans lever has loosened or its in the process of stripping out.
Loosen the allen screw & push the lever back towards the trans
Tighten the allen screw & see if that fixed it
If the lever is still loose on the trans shaft that means its stripping
You can remove the allen screw & put a longer Gr8 screw there & crank it down, normally helps some.
Eventually you'll have to replace the trans lever & that requires loosening the inner primary to get the lever off.... crappy design by HD
Hopelly its the lever & not the trans shaft thats the problem
dawg's Avatar
dawg
**** ain't lined up right. I'm guessing the shaft behind the inner primary might be loose. Probably have a shifter shaft seal that is leaking due to the galling as well. I just fixed a loose shifter on an 05 FLHTCSE and it in turn had a seal leaking because of the wobbling effect. Best thing to do is pull it down, fix the shifter and replace all the seals as you go.
Mikey V
Sep 23, 2013 03:10 PM
Hoblick
Aug 29, 2011 09:32 AM
greybeard2009
Jul 31, 2010 08:47 PM
sporty87
Aug 11, 2009 01:29 AM
fattboy1967
Nov 23, 2008 03:00 PM
