Road King Coil Relocation
Old Aug 7, 2011 | 07:59 PM
TXSNIPER's Avatar
TXSNIPER
Default Road King Coil Relocation
Has anyone moved their coil on a road king? I lifted the tank on my neighbor's road king and on a buddies sporty, also on the sporty I relocated the coil and ignition. It cleaned it up alot under the tank in the front. My neighbor is now wanting to relocate his coil. Let me know if you have any ideas or experience with this.
Old Aug 11, 2011 | 02:17 PM
TXSNIPER's Avatar
TXSNIPER
Okay, I see there is no real interest in this. We have figured it out though and will post some pics when this project is completed.
Old Aug 18, 2014 | 02:14 PM
Saltfish's Avatar
Saltfish
Stage II
Default Coil Relocation
Did you ever re-Locate the coil on the Roadking? I am thinking of doing this on my 94 roadking. Wondering what was involved, how does it look, was it worth it?
Old Aug 19, 2014 | 01:35 PM
Florida Swamp Yankee's Avatar
I raised my tank 3" and had the same issue; the coil looked like crap!
I ended up bastardizing my cowbell bracket to mount my coil on it and then used a $20.00 coil cover from JP Cycles to hide it.
I relocated my horn to the space created under the tank tunnel by bolting to the raceway cover for the wiring. Then I got a sheet of refrigerator magnet material and mounting taped it to the inside of the stock tunnel skirt. This covers the tunnel so torrential downpours can't get in, but still let's the horn sound out.
I'm planning to get the Accel coils that sit on the plugs eventually, but for now this is working out ok.
I like the look and the engine gets to vent more heat than the stock level of the tank.
I also went to the street slammer cover so I can have risers to bring the curve of the bars up so they won't strike the tank... Another money hole!
'07 FLHR , pics in my garage
Last edited by Florida Swamp Yankee; Aug 19, 2014 at 01:37 PM. Reason: More info / pics
Old Aug 22, 2014 | 06:38 AM
somorkc's Avatar
somorkc
on my 04 RKC I attempted this and moved coil to open area below seat. To mount coil you will have to move ground straps to back of that section of frame. then locate one spark plug wire that will reach the front cylinder. after messing with this for a couple of hours I decided that getting the stealth coils was a much better solution. found them for 193.99 at www.mandmcycles.com.
Old Aug 22, 2014 | 08:59 AM
wndchsr2's Avatar
wndchsr2
I lifted the tank on my last bike which was an '07 RK and hated the way the coil looked as well.
Ended up mounting the coil inside the horn cover. The horn was useless anyway so I just mounted that coil inside the horn cover. Really cleaned up the area under the tank after it was lifted.
Old Aug 22, 2014 | 04:24 PM
bklynbob's Avatar
bklynbob
Default $$$
Accel Stealth Supercoils.
somorkc
Aug 17, 2014 06:51 PM
NativeTexican
Jun 4, 2012 08:47 PM
SuspendedUser
Jan 16, 2011 08:55 AM
DR. V-TWIN
Aug 30, 2010 12:19 AM
JohnK-NJ
Mar 6, 2010 03:33 PM
