Trans fluid
Old Nov 13, 2006 | 12:23 PM
ThePunster's Avatar
ThePunster
Default Trans fluid
My owners manual says 24oz (not shop manual - the little book that came with the bike), which is what I put in. The dealer says it should take a quart. Who is correct?
I will check it next ride, but did not get a chance last night as I finished late.
The bike is a 98 FLHTCUI if it matters.
As always - thanks.
DOM
Old Nov 13, 2006 | 12:36 PM
stglideblk's Avatar
stglideblk
Default RE: Trans fluid
my tranny is dead on full mark at 20oz, put 20 and check, primary takes quart
Old Nov 13, 2006 | 12:39 PM
gunrunner's Avatar
gunrunner
Put what book says then check it, trans holds 24-26OZ on that year, 1 quart for primary.
Old Nov 13, 2006 | 01:46 PM
TFR's Avatar
TFR
I changed my tranny oil yesterday and was under the impression 32 oz was the quantity. I put in 30 oz and the tranny was at the full mark. Mines an 07 SG. Perhaps they have changed?
By the way I'm new to Harley, when do you change the primary fluid? Also what oil do you guys use in the crank case and primary?
Thanks
Old Nov 13, 2006 | 01:53 PM
berettag's Avatar
berettag
Go by the dip stick, it'll tell you when it's full.
As far as oil goes........ just search on Oil and you'll see hundreds of answers.
Old Nov 13, 2006 | 02:55 PM
Bill918's Avatar
Bill918
I'd pick up a service manual for your bike, full of great info. I believe the primary gets changed at every 10k, after the initial 1k service.
Old Nov 13, 2006 | 03:02 PM
gunrunner's Avatar
gunrunner
ORIGINAL: TFR
Thanks
You better add the other 2 oz, the 07 holds 1 quart, its bigger than the 5 speed. Most people change trans and primary at same time about every 10k, some change them on every other oil change.
rodnock
EVO
Jan 12, 2010 11:30 PM
cwickgo9
Apr 27, 2008 09:43 PM
pr_capone
Apr 26, 2008 11:25 PM
firestar99
Jul 28, 2006 02:03 PM
OneBlackFly
Oil Archive (no new posts)
Apr 3, 2006 12:59 AM
