Question on long term storage
Old Aug 14, 2011 | 10:25 PM
SpiderPig's Avatar
SpiderPig
Default Question on long term storage
My 93 Softail will be going into long term storage. I am well aware of making sure you change the fluids and have fresh oil in the motor, primary, trans, and even fresh brake fluid for that matter pushed through the system. My question is do you store it with a full tank of gas and the stabilizer ect. OR drain all the gas out of the tank and the carb. Then use a fogging oil inside the tank, carb and each cylinder? I am concerned about all the seals drying out in the petcock and carb and then leaking when I reintroduce gas to years down the road. And the possibility of rust in the tank as well. With the two Ultras both my son and I have barely put 100 miles on the softail this year. We would like to keep the bike but put it away for a while.
Has anyone stored a bike for several years? And what steps are needed for an extended period like this?
Old Aug 15, 2011 | 07:20 AM
grbrown's Avatar
grbrown
The factory manuals cover what they call long-term storage, but I suspect that is really only over winter. All I can suggest is prop the bike up so the wheels are off the ground, lower tyre pressures to roughly half, plus the things you mention.
A friend of mine uses a sealed bag to keep his bike in over winter, so it is well worth looking into them. The bike is enclosed along with dehydrating stuff, to keep it in good condition. They are also available for autos, used for classic cars and the like.
Old Aug 15, 2011 | 08:25 AM
cochon's Avatar
cochon
I don't think that I would leave modern gasoline in that tank. It will turn to sludge in a very short period of time and gum up or degrade anything it is in contact with. I think I would siphon out the tank and run the bike until it stalls out so that the fuel system is empty. Then I would fog the inside of the tank and down the spark plug holes. in my opinion, I would do this and not worry about seals and gaskets "drying" out.
Old Aug 15, 2011 | 08:31 AM
Captain Itch's Avatar
Captain Itch
Sponsor
If it was me I would go out of my way to find non ethanol gas and fill the tank.I would also mix some 2 stroke oil in with the gas...Call me crazy..I have a 46 Indian,and a 49 Harley and this is how I store them..I ride them on occasion,and yes they may smoke but this is what works for me..
__________________
www.Captain-Itch.com
Old Aug 15, 2011 | 08:34 AM
grbrown's Avatar
grbrown
This is the sort of storage cocoon I had in mind.
Old Aug 15, 2011 | 05:47 PM
SpiderPig's Avatar
SpiderPig
All thank you for your reply's and suggestions i appreciate it.I have stored this bike in and out of service since new in 93. However I would run the tank at least when it was stored for the year. So far I am liking Captain Itch's method.
Old Aug 15, 2011 | 09:39 PM
piasspj's Avatar
piasspj
For a year or less use Captain Itches method. For long term get all the gas out as you described. You might even consider filling it with fuel/stabilizer and swapping the fuel out with fresh every 6 months, maybe even a short ride?
Road Star
General Topics/Tech Tips
May 5, 2015 02:30 PM
Ihrugby
Sep 13, 2014 01:13 PM
RidemyEVO
Jan 13, 2011 07:09 PM
hdridernate
Dec 17, 2010 08:22 PM
bosnmate
Nov 15, 2006 06:22 PM
