Leaking oil
Old Aug 17, 2011 | 01:01 PM
bberck's Avatar
bberck
Default Leaking oil
Well I pulled back into the garage this afternoon and when I got off the bike I noticed a couple drops of oil on the floor. Got to get it cleaned up as a lot of is wet with oil as I rode with some sport bike guys last night and was running it pretty hard. It is coming from around the oil filter somewhere. The filter is tight so dont think it is the filter its self. Any ideas or common issues to look for.
I am not looking forward to taking it to the dealer as they couldnt even get the outer fairing back on tight when replacing the radio under warranty.
Old Aug 17, 2011 | 01:07 PM
mkguitar's Avatar
mkguitar
to find the location of an oil leak, spray the suspected area with drug store foot powder.
any leaks will wash away the foot power
year and model of your bike might make it easier for someone to help you, also any mods, such as screamin' eagle air cleaner---?
any oil residue around the air filter, air cleaner housing? or around filler/ dipstick?
if over filled, oil will be blown out on these areas. ( and sometimes, dipstick will be blown out and away, which is way messy
run a pint low if that is the problem
mike
Old Aug 17, 2011 | 01:12 PM
bberck's Avatar
bberck
2011 Street Glide - 8000 miles - just slip-ons
Still have the stock air cleaner and it isnt blow-by. It is definately coming from around the oil filter somewhere. Got it soaking now to clean everything up so i can keep a closer eye on it and see were it starts.
Old Aug 17, 2011 | 01:24 PM
RAP's Avatar
RAP
Check the two allen head plugs on the part that the filter screws onto. They use these at the factory then plug them.
Old Aug 17, 2011 | 01:49 PM
Wassup8687's Avatar
Wassup8687
Great idea. I don't have any leaks but should one surface I'll use this method to locate it. THanks
Old Aug 17, 2011 | 02:10 PM
bberck's Avatar
bberck
Seem to be tight.
Got it all cleaned up but will probally be tomorrow before I can take it out for a ride and see where it leaks.
Old Aug 17, 2011 | 08:25 PM
Sam2010's Avatar
Sam2010
does it have a oil cooler? check around fittings?
Old Aug 17, 2011 | 08:48 PM
roadgliderick's Avatar
roadgliderick
i agree if u have a oil cooler check that area.
Old Aug 17, 2011 | 08:52 PM
bberck's Avatar
bberck
The oil cooler seems fine but hopefully tomorrow I can narrow down the area a little better.
Did talk to a guy today with a 2011 RGC and he had a leak in the same area and it was the from a gasket behind the piece the oil filter screws on to. Really looks like mine maybe from the same gasket.
Old Aug 17, 2011 | 09:28 PM
Geoff's Avatar
Geoff
Good tip. I once had a leak in this area. Tightening the two allen head screws was the fix.
