Bub 7 2 into 1 too loud.
Old Aug 18, 2011 | 09:29 PM
truckerdave's Avatar
truckerdave
senior experienced all-knowing leader of the unwise
Default Bub 7 2 into 1 too loud.
Yeah, yeah. I'm not too old either, just dont like loud on touring bike. It's on a 103 with cams so it's much louder than it would be on stock bike. Noticed the baffle is not wrapped with sound absorbent packing. Wondering if that would lower sound level to acceptable. I know they sell quiet baffle for this pipe fpr $70+ but i also have HP+ baffle that came from another muffler that would not be hard to insert into bub. Any suggestions?
Old Sep 4, 2012 | 10:19 PM
mnchopper98's Avatar
mnchopper98
Stage II
You can get baffle wrap at hitching post, or other bike shops. I have a bag of it here and it was cheap. Pull it and wrap it yourself. It will deepen the tone and get rid of some of the ting.
Old Sep 4, 2012 | 10:40 PM
drukanfu's Avatar
drukanfu
Put a stock headpipe with the CC in. It will give you a nice deep mellow sound. The stock pipe has great flow and the CC has very, very little flow restriction.
It traps heat to burn hydrocarbons.....move the passenger pegs out an 1" if it's a problem.
Old Sep 4, 2012 | 10:50 PM
mkguitar's Avatar
mkguitar
The techs at Supertrapp suggest that when packing is removed from a muffler, that the gasses slow ( loose velocity, because the tract is suddenly wider), and may eddy and loose direction as they flow in and out of the baffle to the chamber where the packing was.
this can result in lost performance.
so no matter what you do, you should wrap the baffle for performance sake.
The packing will absorb primarily high frequencies
Mike
Old Sep 5, 2012 | 03:54 PM
TUCCI's Avatar
TUCCI
I've had exhausts from them before and they are loud....and their quiet baffle is too close to the same to call it different. I can see why manufacturers don't take em back after you've installed them, aside from tuning influence with color changes they never sound the way you expect or promise for that matter.
jus2anoyu
Sep 22, 2013 03:16 PM
PopsHD
Jul 24, 2013 10:13 PM
jluvs2ride
Nov 28, 2012 02:04 PM
SMOKEin
May 14, 2009 12:05 PM
gpp
Feb 14, 2008 09:28 PM
