I smell Oil
Old Aug 20, 2011 | 01:59 AM
SeeMeDo's Avatar
SeeMeDo
if your seeing a little oil inside of your air cleaner you might have to much oil in the can which you can adjust by using a baster borrowed from the kitchen. When i smelled oil from my departed 95 FLSTN that was the source didn't take much oil just a little bit.
Old Aug 20, 2011 | 02:19 AM
Holster Maker's Avatar
Holster Maker
You all are smelling the normal blow-by into the air cleaner..........breathing!
Worst when run hard or hot, very normal. I've been smelling it since 1978 and smell it on my new TC.
On my last 2 Evo's I routed it outside to a breather real low on the bike and didn't smell it as bad and a-c was stayed clean.
Keep your oil at 1/2 mark, helps a lot.
Old Aug 20, 2011 | 02:23 AM
Maclugie's Avatar
Maclugie
Yep, it is normal. The smell of a fine running machine!
Old Aug 20, 2011 | 05:18 AM
Geezer glider's Avatar
Geezer glider
The transmission is vented, that is why you can smell something. I never really noticed much in smell on my bike till I switched to Redline heavy shock proof, now I smell gear lube which is very distinctive. I really like how much smoother the shifting is that I just deal with it. Just look around your bike and make sure you have no leaks, if none, ride it and enjoy the day.
As a side note, I needed to replace a clutch cable, while doing that I seemed to had gotten some oil on the exhaust bracket. No matter how much you clean up, you just don't get it all, well it makes a little smoke and really smells when that bracket got hot for a few rides.
Old Aug 20, 2011 | 07:01 AM
broziff's Avatar
broziff
Originally Posted by rlh7677
Look where your clutch cable enters the trans, the clutch cable may have just a drop of oil on it and/or it may be , one drop at a time, working it's way down the cable to under the engine, when the engine and clutch cable is hot it will omit the oil smell you're smelling, don't try to stop it, you can't, it does'nt hurt anything and it gives you that "Harley smell" !!!!
I had the same leak at the clutch cable dealer said they tightned it at my last service.
Old Aug 20, 2011 | 08:04 AM
mariner227's Avatar
mariner227
Keep an eye on your transmission oil level. I may be leaking very slow and burning off on your exhaust.
Old Aug 20, 2011 | 08:18 AM
lionsm13's Avatar
lionsm13
Check the 2 fasteners where your pipes mount to, right under your tranny cover and make sure that they are tight..
You may have to remove one of the heat shields to do this unless you have the right tool.
Also if you smell gear lube, check the back side of your right muffler for "crusty" feeling debris. If you can feel something like that on your muffler, you more than likely have a leak, and it is more than likely coming from the the 2 fasteners where your pipes mount under your tranny and then leaking onto your muffler.
Old Aug 20, 2011 | 08:21 AM
spider14043's Avatar
spider14043
I also smell the Redline when it is fresh.
Old Aug 20, 2011 | 08:59 AM
Uncle Larry's Avatar
Uncle Larry
I think it's the nature of the beast ... mine's had an odor ... fragrance ... aroma .... since it was new and I now refer to it as "Eau de Harley" .... Never noticed it on any of my older scooters.
Old Aug 20, 2011 | 09:04 AM
atrain68's Avatar
atrain68
You are smelling the natural musk of a Harley-Davidson. You probably are smelling blow by vented into the air cleaner and a nice aroma coming from the tranny. Damn that is a great smell, isn't it?
