New Road Glide -dangerous shaking-front end
Old Sep 19, 2011 | 08:03 PM
  #71
patflynn2's Avatar
patflynn2
6th Gear
Default 2011 Road Glide Shake in front end
I had the same issue when I first got my bike but I also noticed that when I decelerated I felt a front end clunk like a Fall-away issue. So they adjusted my neck and I have not felt it any more.
Good Luck, Hope you get it figured out!
Old Sep 19, 2011 | 08:23 PM
  #72
KahunaJim's Avatar
KahunaJim
Originally Posted by ShakeyGlide
Here is the link about 'SERVICE BULLETIN- Road Glides '09 to '12 - Fall Away
If I did this correctly (still new @ PC stuff) - If not see my new post today (titled the same as above) around 11:30am - it works.
http://www.glide-pro.com/wp-content/...djustment1.pdf
Hope this is of help to all Road Glide owners from '09 forward!!
....it says '09 Road Glides so the dealer will tell me it doesn't apply to mine....which is an '11 and does it not only at decel but when the cruise is set on 40!
Old Sep 19, 2011 | 08:35 PM
  #73
stro1965's Avatar
stro1965
Had my neck bearings tightened down today....didn't change a thing, still wobbles on decel.
Old Sep 20, 2011 | 07:19 PM
  #74
ShakeyGlide's Avatar
ShakeyGlide
Default Ours is a 2011 as well!
Ours is a 2011 as well - started at just over 400 klms. It applies to 09 & newer Road Glides.
Our Dealership told us that as well - once they checked.
Our problem was that we were told that they had made the adjustment. So we didn't question it again. They didn't adjust it to the specs in the bulletin! Just assumed it was like all the others from years past. No-one ---not even the other mechanics questioned the head mechanic on the Fall Away adjustment that he made. If someone had - it would have been fixed the next day - instead they basically rebuilt the bike to find what was wrong - and still didn't find it because they no-one checked the service manuals.
Hope this info helps.
By the way - ours is Merlot as well - what awesome colors - depending on the light!!
Old Sep 20, 2011 | 07:28 PM
  #75
ShakeyGlide
Did you have the Service Bulletin with you to show them? I posted it awhile back.
That seemed to be 'THE' issue with the decel wobble - they say it was done (just like they told us) but the problem was they did it to the original specs - pre- '09 (which I believe was a 3). We didn't question it - cause we didn't know about the specs - (read my posts - you'll see all the BS we went thru).
Turns out the head mechanic did the adjustment. The other mechanics never questioned or checked the Service manuals for the correct adjustment - so no-one questioned his adjustment - just assumed he did it right.
Ask them what they adjusted the fall away to & then check the service bulletin - see if the numbers are right.
Good luck.
We are now extremely happy with the bike - such a simple fix - yet nobody thought to re-check!!
Old Sep 20, 2011 | 10:22 PM
  #76
Deuce Bigelow's Avatar
Deuce Bigelow
I tried to adjust it tonight, but I don't have the "tool" so I tried using a small screwdriver.
I can get the end of the screwdriver on the adjusting nut but couldn't turn it, I tried tapping on it with a small hammer and lowering the bike off the jack and still no luck turning that nut.
my fall away is a little over 2 swings.
it's a bitch getting to it with the fairing in the way...
Old Sep 21, 2011 | 09:55 AM
  #77
ShakeyGlide
Here is the link for the service bulletin - depending on the model fall away is different specs - Ours was between 1 & 1.5. Also - the dealership did the work (we're not mechanically inclined) sorry we could'nt be of more help.
Old Sep 21, 2011 | 02:57 PM
  #78
Deuce Bigelow
taking a ride to Harbor Freight to try an find something to use as a tool..... I now know what I need to be able to turn that nut...
Old Sep 21, 2011 | 04:04 PM
  #79
stro1965's Avatar
stro1965
Good luck.
Yeah, they were familiar with the service bulletin and had done it on several Road Glides. They were reluctant to do it on my Ultra but did so at my urging. I'm right at 2 swings now and still wobbling! This issue is NOT limited to Road Glides.
Old Sep 22, 2011 | 02:56 PM
  #80
petewerner's Avatar
petewerner
mine just started at 4200 miles, same as everyone else states. I took mine to service dept and borrowed a grease gun and filled the neck and bearings with grease until it came out the top and bottom. As soon as I finished I took it for a spin and no wobble! The head shake stopped. Now my thoughts on this are that the grease took up the space that allowed the wobble. Now I get 1.5 instead of 3 on the test... I don't think it will hold this tolerence for long and the ultimate fix is to tighten the steering head bearings... It's a good way to see what's up...
