(5) Primary Torx Screws
Old Aug 28, 2011 | 07:46 AM
Gearhead3's Avatar
Gearhead3
Good advice from everyone....a hand impact to remove them and then replace with allen head screws. One thing I did that no one has mentioned though, is that I went ahead and replaced mine with polished stainless steel. A dab of antiseize on the threads and after snugging them down I don't worry about corrosion ruining the looks of my bolt heads. Ace Hardware carries a wide selection of stainless as well as other types of fasteners. Good luck with whatever way you decide to go!
Old Aug 28, 2011 | 08:23 AM
JohnnyC's Avatar
JohnnyC
Mine come off and on several times a season so they never have time for the heads to seal to the cover.
Torque specs for the primary cover bolts is very little, just barely tight.
I can see that a bike that hasn't been serviced in a long time having situations. I find it interesting that once the heads are drilled out the threaded remains came out by using just turning them with your fingers ... Who'd thought!
Old Aug 28, 2011 | 08:27 AM
overhead's Avatar
overhead
My guess is it is not that they are actually torqued down with much force, my guess is that something used in production is causing the head of the torx to stick to the actual cover, if that makes sense. I would be curious if just giving the torx a solid tap with a hammer with either a torx driver or torx racket install. My guess is they would come right out just like they do with the impact driver.
Old Aug 28, 2011 | 09:23 AM
aggro_jo's Avatar
aggro_jo
stick the t-27 bit on an extension and heat it up with a torch. Get it hot and a put it in the fastener and give it a few downward love taps while applying loosening pressure. The white threadlock will break loose.
There is nothing magic about working with torx heads. They are as easy to use as an allen. Especially in a light torque setting.
For the life of me I don't understand why people have such issues. < not directed at you OP. just a general statement
Old Aug 28, 2011 | 10:04 AM
drukanfu's Avatar
drukanfu
Originally Posted by dawg
Use a hand impact. A lot of folks swap them out for allens. I don't have a problem with the torx so I leave them on.
Hand impact wreches are inexpensive, even a cheap one will last pretty long for the average guy to use. Harbor freight $ 6.99
Old Aug 28, 2011 | 10:07 AM
TWIN CAM 96's Avatar
TWIN CAM 96
Originally Posted by Tek74
OK.....I'm at 4k miles on my 2011 RGC, so I changed the Oil and Tranny fluids. Then I intended to change the Primary fluid, but the (5) torx screws will not budge with my drill on max power. One screw even started to strip. Is this some kind of friggin joke from Harley?
So now I have to bring my bike, my primary fluid, and my new primary gasket to the stealer and pay them 30 minutes of labor to remove (5) friggin screws. I definately want to trash these (5) torx screws for some regular hex screws. Has anybody done this? Any "specific" recommendations?
The allen's are 1/4 x 20 x 1/2 Grade 8
you can buy there in regular allen head or button head allen both come chrome!
Make sure you use never seize on the screws when you reinstall them!
Old Aug 28, 2011 | 11:03 AM
Port Dawg's Avatar
Port Dawg
Originally Posted by Pastor John
When mine got stuck like that, I ended up drill ion off the heads and replacing with allen heads as others have done. Interestingly, it was the heads that were stuck - as soon as the heads were drilled, the shaft of the screw came right out with my fingers. Now I have chrome allen heads on there, and they come out like they should every time.
Was that on your 2011?
chugger93
Jun 28, 2016 11:21 PM
dickey
Apr 8, 2016 11:17 AM
baust55
Jul 16, 2012 07:09 AM
chesterbud
Oct 26, 2008 10:50 PM
Arctic Badger
May 31, 2007 12:49 AM
