Brake Light Switch Removal
Old Aug 30, 2011 | 05:24 PM
Gliden's Avatar
Gliden
Default New Indy in town
Originally Posted by IBHarley
I just removed it by pulling with a small pliers if were talking about the rear switch located on the lower frame on the right side of the bike while sitting on it And then just unscrewed the switch
Poof! Your now an Indy! (sort of) lol...good job!
Old Aug 31, 2011 | 01:23 AM
Mongo7337's Avatar
Mongo7337
6th Gear
Flat Screw driver Twist don't pry
Old Aug 31, 2011 | 03:04 AM
Mongo7337's Avatar
Mongo7337
6th Gear
Flat screw driver Twist don't pri
Old Sep 9, 2011 | 01:08 PM
cowboybob56's Avatar
cowboybob56
Default Brakes
I was told by a motorist my brake light does not brighten(work). I got to work and checked. My front brake illuminates the brake light but the rear does not. I suspect the rear master cylinder. I will check it when I get home.
Old Sep 9, 2011 | 02:15 PM
KCFLHRC's Avatar
KCFLHRC
Replacing the front switch isn't that bad. Took me about 2 hours. You really need 3 hands instead of 2. The hardest part was holding the wires while soldering them. Anyway, glad it's done. Bought the switch through Dennis Kirk for about 1/3 the price of HD.
Old Sep 9, 2011 | 02:21 PM
Cotton Hill's Avatar
Cotton Hill
That rear brake light switch seems to be a problem for many riders. It's a common failure item. With a simple fix.
Mike Simeone
EVO
Aug 26, 2018 08:52 AM
rideamap
Electrical/Lighting/Alarm
Sep 16, 2014 01:00 PM
decencyxdefied
Feb 18, 2014 11:38 PM
trooper_355
Mar 2, 2010 07:17 PM
nobake
Apr 8, 2008 08:17 AM
