Leaking Transmission Fluid
Old Oct 30, 2011 | 02:28 PM
Jackie Paper's Avatar
Jackie Paper
Interesting but I have work on two Harleys since I posted 8 above that I believe the problem was coming from changing the filter and letting the oil run down on the cable. Gets in the outer protective cover (not the cable but the slide on sleeve) and runs down for a long time.
Old Oct 30, 2011 | 08:08 PM
Lowcountry Joe's Avatar
Lowcountry Joe
My money is on the cable's O-ring not sealing properly and allowing tranny fluid to leak out, every so slowly.
Old Oct 30, 2011 | 08:41 PM
Panshovevo's Avatar
Panshovevo
On mine, the cable housing threaded end is well sealed in the tranny end cover. I experimented today with raising the cable above the end. So far, after a short ride, no drips. Time will tell.
jimihd
Apr 29, 2017 09:25 PM
Scudda
Sep 29, 2015 01:20 PM
Glide'n09
Apr 7, 2010 10:02 PM
bg5377
Jul 30, 2007 01:45 AM
Sally88
Sep 22, 2006 11:14 PM
