Please listen
Old Sep 4, 2011 | 03:13 PM
FATBOB.'s Avatar
FATBOB.
Default Please listen
AFTER RIDING FOR AN HOUR OR SO, I HEAR THIS..BUT NOT COLD. IT COMES FROM
THE RIGHT SIDE IN THE FRONT ..WHEN DOWN SHIFTING, ONCE IN A WHILE WHEN HOT ,I
HEAR ....AKTING.. FOR EVERY DOWN SHIFTING..NEXT STOP, THE USUAL CLUK . WHAT YOU
THINK...I HAVE A FLHX 2011, 8000 MILES ON IT...THANKS VERY MUCH...
http://www.youtube.com/watch?v=rA49wjuKENw
Old Sep 4, 2011 | 03:39 PM
CANADIAN HARLEY's Avatar
CANADIAN HARLEY
Arrow trans noise
Hard to tell from video but my guess is the same noise we all have ,
Do a search on transmission noise at idle to see all the threads.
Old Sep 4, 2011 | 04:00 PM
dontdropit's Avatar
dontdropit
Active Streak: 30 Days
Active Streak: 60 Days
I have the same sound on my 2012. My dealer calls it gear rattle. Only there when hot and in neutral. I do believe that's what it is because when I pull in the clutch it goes away. Sure sounds like a piece of junk though. This is my seventh harley and the first one that has noticeable gear rattle. I'll likely put some thick fluid in to reduce the noise some. Makes me want to not put it in neutral around other riders on other brands because it certainly attracts attention. Personally I feel it's too loud.
Old Sep 4, 2011 | 04:11 PM
FATBOB.'s Avatar
FATBOB.
EVEN WHEN when I pull in the clutch , it DOSNT GO AWAY... AFTER 2 OR 3 STOPS AND GO
OR AFTER ACOUPLE OF MILES ITS NOT AS LOUD .. AND THAN IT COMES BACK...AS YOU
CAN HEAR IN THE VIDEO, YOU HEAR IT IN FRONT OF THE ENGINE!!!!NOT NEAR THE TRANS..
WEIRD... THANKS GUYS
Old Sep 4, 2011 | 04:17 PM
NewAge's Avatar
NewAge
That doesn't sound normal to me. Dealers like to say things are normal so they don't have to deal with them. If i were you, I would take it in to the dealer and say FIX IT. If they again say it's normal, say PROVE IT and go hand pick a random 2011 FLHX from their floor and say let me hear THAT one do it. My 2010 FLHX does NOT sound like that. JMHO
Old Sep 4, 2011 | 04:59 PM
jmacdonald5's Avatar
jmacdonald5
..is that the new "103 Clean-Diesel" I've been hearing about?...seriously...I'd be aggravated if I had to listen to that every time I went riding....not normal!
Old Sep 4, 2011 | 05:04 PM
aviaator's Avatar
aviaator
Almost sounds like leaking exhaust gasket. They can sound like a tapping noise, but odd only does it when hot.
Old Sep 4, 2011 | 05:17 PM
Reaper22's Avatar
Reaper22
Damn man Seriously,That's the exact same sound I heard before the sprocket spun on my camshaft, How long has it been doing it?? Mine also sounded like it was comming from tranny cuz I thought I would make it home and I got about 2 miles and it spun. read my post about my issue I posted pics.At least you have warrenty left, I would ask that dealer if your skoot has those pos pressed cams.. That's bs should not sound like that, I also thought it was exhaust leak cuz I was getting some backfiring..
Old Sep 4, 2011 | 05:24 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
Nope, that ain't normal. Sounds like it could be an exhaust leak. Anything else is likely to be expensive.
Find a different dealer, or maybe an Indy that does warranty work.
Kevin
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
Old Sep 4, 2011 | 05:29 PM
Zap's Avatar
Zap
If this is any consolation, some of the noisiest
Harley engines I've heard, were some of the fastest.
On the other hand, maybe you need louder pipes.
