How do you like the sound compared to stock? Which baffle did you get? I'm considering the same setup. I want more sound, deeper, but not abnoxious. I'm also considering V & H dresser duals and rineharts. Anyone have any opionions on that setup? Thanks!
Just seemed to me the jackpots got louder after some miles on the pipes. Real deep and when you cruise they are not that loud to me. When you get on the throttle you will definitely notice.
I have alot of miles on the jackpots. It appeared
I just got them with the standard baffles. Not obnoxious. Smooth on idle & cruise, aggressive and deep on throttle. Perfect balance. Had Rhineharts beforehand but found them to be a bit high-pitched for me.
I would not use the Jackpots with the CAT still in place though as one the of pipes had begun to barely yellow on the edge while waiting for the header pipe to come in. Temperatures went down drastically, and confirmed by a laser thermometer, once the new header pipe was in place and the CAT out.
Not familiar with V & H. For what it's worth, local HD dealer complimented on the quality of the Fuelmoto header pipe.
Thanks! I'm leaning toward the jackpots. Do you have the 3.5 or 4 inch?
