Drain screw
Old Sep 9, 2011 | 10:33 PM
Badgerbob's Avatar
Badgerbob
Default Drain screw
Just put chrome lowers on and it would seem as though the right side lower drain screw is stripped. Do not want to overtighten, but is still leaking. It feels as though I am just at the point where it will. suggestions please on repair.
Old Sep 9, 2011 | 10:37 PM
2black1s's Avatar
2black1s
Chrome lowers / drain screw? What are you talking about?
DSMHAWG's Avatar
DSMHAWG
New crush washer and thread tape on the threads of the screw. Worth a try???
DSMHAWG
Old Sep 9, 2011 | 10:58 PM
Badgerbob's Avatar
Badgerbob
Front shock chrome lowers and the drain screw at the bottom of the lower. For draining your fork oil.
Old Sep 9, 2011 | 10:59 PM
Badgerbob's Avatar
Badgerbob
DSMHAWG
Brand new screw and crush washer.
Old Sep 9, 2011 | 11:03 PM
dawg's Avatar
dawg
Was it a set of HD chrome lowers or did you do one of those chroming swap deals? If it was a swap deal, you might want to chase the threads and make sure the area is flat and no nubs, etc. If it is stripped you can tap it to the next size up.
Old Sep 9, 2011 | 11:21 PM
2black1s's Avatar
2black1s
Ah - got it.
Like dawg said check the sealing surfaces (including the washer/seal) for imperfections. And check the threads on the drain screw.
If the sealing surfaces and the threads on the drain plug are ok then keep tightening until the leak stops. If the threads in the lower housing strip before the leak stops then the threads were probably bad to begin and needed repair anyway, so nothing is lost.
sendtorandy
Mar 12, 2011 04:50 AM
cmvsm
Nov 18, 2010 12:12 AM
ezriderpgh
Jun 19, 2009 09:24 PM
joechief
Jun 14, 2009 09:46 PM
cdestuck
Feb 22, 2009 01:40 PM
