07 SG Starter Needed...Options?
Old Sep 11, 2011 | 08:55 AM
cabowabodude's Avatar
cabowabodude
Default 07 SG Starter Needed...Options?
Well I've had a few misfires when I hit the starter button. Battery tested good and all the connections were tight. So I pulled the starter out and found several teeth in poor shape. I have a 07 SG with a 103" Stage II set up. I'm looking for options on a solid starter. Has anyone upgraded their starter. I see the HD starters ( P/N 66477-10) are about 430.00 Is there an aftermarket upgrade that will perform better for around the same price?
Thanks
Mark
Old Sep 11, 2011 | 09:44 AM
18BKLR's Avatar
18BKLR
Change the Bendix on it and use it till it stops. They are made of a softer metal than the flywheel. Change it out and see how long it lasts. I wouldn't just trash a starter because the Bendix is worn. I am sure you can find an aftermarket part that will perform better and it will be much cheaper than a whole new starter.
Old Sep 11, 2011 | 09:51 AM
mkguitar's Avatar
mkguitar
yup- when the 'extreme starter' craze started in the 90's, I kept quietly servicing my starters on my bikes--- they are all working well ( except for the starter on the '53).
some of the aftermarket starters are gone from the market and maybe weren't so good after all.
The starter on my 88 FXRP I have rebuilt each part many times. The only fatal fault is if the windings burn up.
replace the bendix and proceed.
btw there was starter on the classifieds board a couple of days ago cheep.
Mike
Old Sep 11, 2011 | 09:57 AM
Stiggy's Avatar
Stiggy
Absolutely agree with the above. The "Super Starters" of the 90's were nothing more than stators with more windings. The stuff that broke inside though, ( reduction gearing, teeth, etc,) were the same components as stock.
Your starter is not at fault for what's tearing it up. Just keep fixing it.
Old Sep 11, 2011 | 10:54 AM
dawg's Avatar
dawg
starter 31618-06A $375.00
clutch sub assembly 31633-07A $113.00
solenoid repair kit high output 31604-06 $65.70
Old Sep 12, 2011 | 08:48 AM
cabowabodude
Ok, what is needed to change out the Bendix? Where does one go to purchase a new Bendix.
Old Sep 12, 2011 | 11:05 AM
speakerfritz's Avatar
speakerfritz
you will be replacing again if you do not root cause this......my take is you need to add compression release...others will say replacing your compensator will do the trick.
Old Sep 12, 2011 | 10:52 PM
Harleyboyddk's Avatar
Harleyboyddk
Your big inch motor was probably tight when new and took time to lossen up. Takes a toll on the starter drive. Replace drive and will probably be good now the motor has broken in and loosened up.
stokes
EVO
Jul 6, 2011 10:53 PM
sunup420
EVO
Feb 7, 2010 11:58 AM
DAVETHEBUILDER
Exhaust System Topics
Jul 1, 2007 11:30 PM
mikesta1
Welcome Area Only
Apr 23, 2007 11:20 AM
Bdub
Dec 7, 2006 03:52 PM
