Strange vibration..2009 FLHX
Why'd they do that? They obviously got tired of warrantying scissored crankshafts, which entails engine replacement if under warranty.
I wouldn't own a 96" motor without knowing what my runout is. It takes all of about an hour and a half to check. ( Please search 'Scissored crankshaft' here in the Forum to see how prevalent this problem is.)
Run out problems are not static, they tend to get worse over time. Vibration increases, weaker stuff starts to break, and run out continues to grow. It also increases with heavy braking with the clutch engaged, bouncing over RR tracks with the clutch engaged, hard acceleration and burnouts.Just about anything that 'torques' the crank.
Where you go from there means you have to know where you are now. The gentleman with the .004" runout would have gotten me a brand new motor back in my day, when warranty was .003" to '0.' And as .004 is no doubt tolerable, he'll sense it if it starts getting worse.
I want to know before I drop big money on wheels or cams and headwork if I've got a problem. Consider directing savings to that crank project instead or plan to sell the bike and start over.
Sounds drastic? How about $5,000 in upgrades and THEN discovering that you've got a motor problem?
I guess I consider it a lesser of two evils to my way of thinking.
