Damaged crankshaft threads
Old Sep 12, 2011 | 02:53 PM
2009blackpearle's Avatar
2009blackpearle
Default .012 is spec
think i saw some where in posts once upon a time that run out spec is .012 seems about .0115 too high to me , but Im pretty sure thats harleys mile wide spec for comp end of shaft, I used to work at a factory making drive shaft parts and a half a thou wasnt even good enough for the spec we had,
Old Sep 12, 2011 | 04:06 PM
djl's Avatar
djl
Originally Posted by Biggzed
I rode a friends bike that we measured at .007. mine is at .0045 last check. I couldn't tell a difference between the two bikes.
Zach
Not saying much.. Ride one with .0005 runout and see what you think. But I am happy for both of ya; suggest you keep an eye on the oil pump gerotors and cam plate bushing.
Old Sep 12, 2011 | 04:10 PM
Biggzed's Avatar
Biggzed
Originally Posted by djl
Not saying much. RideHappy for both of ya. Keep an eye on the oil pump and cam plate bushing.
Don't get me wrong. I'm not happy about the runout I have, but I'm also not feeling like I need to yank out the crank and have it worked.
All I was trying to tell the OP was that all is not lost if he comes in at something slightly above .005. I guess it depends on the individuals comfort level.
Zach
Old Sep 12, 2011 | 04:11 PM
djl's Avatar
djl
The spec for warranty purposes was changed from .003" to .012" in 2007 when the crank assemblies were sourced from a foreign supplier.
Old Sep 12, 2011 | 07:31 PM
customsoftail200's Avatar
customsoftail200
I measured the runout and I have about .0045 on the primary side.. Sounds like it should be OK. Now I have to see if the threads can be repaired.
Old Sep 13, 2011 | 04:26 PM
djl's Avatar
djl
I agree with Bigzzed. Wouldn't pul the lower unit and send the crank out to balance and weld for .0045" runout. But I would check it each season or if you should notice a new vibration. If it gets bad enough, it will destroy the oil pump and will cause bad juju to happen to your motor.
Old Sep 13, 2011 | 05:02 PM
Biggzed's Avatar
Biggzed
Not trying to be condescending, but was that total indicated runout (TIR where runout on both sides of zero are added together) or was it the max reading you recorded?
The specs djl listed above are TIR.
Zach
Old Sep 14, 2011 | 07:25 AM
customsoftail200
Yes, that was total runout, When I had it set to 0, it had gone to almost -.001 and then positive between .003 to .004.
Old Sep 14, 2011 | 10:50 AM
Biggzed's Avatar
Biggzed
Cool. Hopefully the threads clean up nice and you can get back on the road.
Zach
dlpuette
Jul 1, 2015 12:04 PM
Javieret
EVO
47
Apr 23, 2015 05:47 PM
customsoftail200
Exhaust System Topics
Sep 11, 2011 03:00 PM
Thirdup
Aug 22, 2008 07:56 PM
Gulfstream
May 8, 2008 09:36 AM
