Air filter..... oil or not
Old Sep 14, 2011 | 06:15 AM
Mikekoz13's Avatar
Mikekoz13
Default Air filter..... oil or not
I'm replacing my air filter with a stock filter. Does the new filter need to be oiled before installing?
Thanks-
Mike
Old Sep 14, 2011 | 06:17 AM
jjnoble's Avatar
jjnoble
Stock filters do not need to be oiled.
Navy UC Rider's Avatar
Navy UC Rider
Do not oil the stock filter, the paper will turn to mush.
Old Sep 14, 2011 | 07:51 AM
Mikekoz13's Avatar
Mikekoz13
Thanks! I That's what I thought but my one Friend that has been riding forever insisted that I oil it. He had me second guessing myself.
Old Sep 14, 2011 | 08:00 AM
TheDon81's Avatar
TheDon81
Get a K&N then clean and oil and you will be on your way.
Old Sep 14, 2011 | 08:04 AM
Jackie Paper's Avatar
Jackie Paper
The stock is designed to be run as is out of the box.. If you hold it up to the light you will notice it's rather dense. However I do not believe it would turn to mush as much oil as these V twins throw out. If you hold one of these wasable SE style filters up to the light you can see thru it. They need all the help they can get, hence oil. I worked on one the other day that someone must have taken a air gun too a little too vigorous. It has numerious places that it appeared to be completely open. You could not see it till you held it up to the light. Crap like this is probably not doing a lot of filtering.
Old Sep 14, 2011 | 09:17 AM
nivensid's Avatar
nivensid
Default Oil???
Not to hijack this thread, but I put on a Arlen Ness Big Sucker set up the other day. Does this filter need oil, it looks to be like a K&N but no mention of adding oil and none supplied?
Old Sep 14, 2011 | 10:12 AM
TUCCI's Avatar
TUCCI
Originally Posted by grf000
The stock is designed to be run as it. If you hold it up to the light you will notice it's rather dense. However I do not believe it would turn to mush as much oil as these V twins throw out. If you hold one of these wasable SE style filters up to the light you can see thru it. They need all the help they can get, hence oil. I worked on one the other day that someone must have taken a air gun too a little too vigorous. It has numerious places that it appeared to be completely open. You could not see it till you held it up to the light. Crap like this is probably not doing a lot of filtering.
I'm sorry I'm not sure I understand what your saying, don't use any oil on the stock filter or yes use oil on it? I thuoght the service manual said something about using oil...I could be wrong tho. If its yes use oil, what type are we using I've got KN recharge oil is that good?
Old Sep 14, 2011 | 10:30 AM
TheDon81's Avatar
TheDon81
Stock Harley's come with a paper airfilter, that requires no oil.
Old Sep 14, 2011 | 10:43 AM
bmaier's Avatar
bmaier
My Big sucker filter was preoiled new out of the box. It it isn't you'll need to oil it.
