Light Bulb Blows Out Ignition?
Old Sep 13, 2011 | 03:08 PM
Chris802's Avatar
Chris802
6th Gear
Default Light Bulb Blows Out Ignition?
So I went to change out a turn signal bulb on the back of my Road King to an LED one. When I plugged in the LED, nothing happened. I put the bulb back in...did not light up. Tried the other side...did not light up. Decided I would try to start the bike and move it into the garage...then I noticed the ignition wouldn't start (doesn't turn over) and the speedo backlight is out and the odometer/clock are not on. I checked the fuses...nothing obvious. I'm thinking maybe something blew with the security system or the rear turn signal module? Front lights are on, but turn signal buttons do nothing.....any suggestions?
Old Sep 13, 2011 | 03:10 PM
Chris802's Avatar
Chris802
6th Gear
Forgot to mention I installed the ThunderMax TBW about 2 months ago....just in case that's a possibility
DannyZ71's Avatar
DannyZ71
Did you unhook your battery when you made the switch?
Old Sep 13, 2011 | 03:19 PM
stro1965's Avatar
stro1965
I think it would still turn over, and probably start, even if he didn't go through the initialization. Probably run like crap though. I could be wrong. I'd double check those fuses.
Old Sep 13, 2011 | 03:32 PM
DannyZ71's Avatar
DannyZ71
The reason I asked that is he could have tripped something in the ECM. Try disconnecting the battery for a few minutes, then reconnecting it. That is, if all the fuses are fine.
Old Sep 13, 2011 | 09:41 PM
Chris802's Avatar
Chris802
6th Gear
I figured it out after spending a little more time in the fuse panel. It ended up being the "battery" fuse. I must have missed it last night. I swear if it wasn't for the stupid mistakes I'd have nothing to learn from. Thanks for the replies.
danl
Jul 15, 2011 09:16 AM
anteekhawg
General Topics/Tech Tips
Dec 7, 2010 02:38 PM
car5car
Nov 27, 2009 08:00 AM
mimo
Mar 13, 2009 08:43 PM
jamesf0622
May 21, 2007 10:52 PM
