Check Engine light came on today.
Old Sep 14, 2011 | 08:03 AM
Toypuller's Avatar
Toypuller
Looks like you have an issue with your throttle position sensor. Thats the P2135.
The other code is a historic, telling you that you went into safe mode.
It could be any number of things in the throttle position sensor, but a loose or shorted wire may be showing itself after a few hundred miles.
Ride on and try to duplicate it again.
Old Sep 14, 2011 | 08:24 AM
vtwinbob's Avatar
vtwinbob
try re-setting your TPS to do this, Turn Ignition switch to OFF & Run/Stop switch is to Run, now turn on the ignition switch, leaving the run/stop switch in the run position, for 10 seconds, then turn off for 10 seconds do this 3 times, on the 4th try start the bike and DON'T touch the throttle leave it run for for 5 min or so this will re-set your TPS. hope this helps.
Old Sep 14, 2011 | 08:38 AM
dyna07custom's Avatar
dyna07custom
you may also want to check that throttle grip and make sure you dont have it to loose or to tight up against sensor
Old Sep 14, 2011 | 08:44 AM
Wanna Ride's Avatar
Wanna Ride
Just out of curiosity to you guys who are having problems after the bar install... did you disconnect the battery, or pull the maxi-fuse before installing the new bars?
Old Sep 14, 2011 | 11:14 AM
vzts4q's Avatar
vzts4q
Originally Posted by C908
Thanks for the answer on the two codes, does anyone know exactly what they mean ?
The descriptions and corrective measures are in the electrical service manual.
Attached a scan of both pages.
But if you ever want to do any work on your own bike or if you just want to understand the dealer tells you.
Buy the service manuals!
Attached Thumbnails Check Engine light came on today.-p2135.jpg   Check Engine light came on today.-p1511.jpg
Old Sep 14, 2011 | 01:57 PM
C908's Avatar
C908
The person that did my install did not disconnect the battery or pull the fuse. What exactly happens by not doing either one of these things? Thanks
Old Sep 14, 2011 | 04:39 PM
dwg dave's Avatar
dwg dave
Just got back from picking up my 11 EG classic with same problem. Attached is the repair the did to supposedly fix the problem
Old Sep 14, 2011 | 04:42 PM
dwg dave's Avatar
dwg dave
Here is the attachment, for some reason it did not attach first time
dwg dave's Avatar
dwg dave
OK, fug it, pm with a e-mail address if you want it
Old Sep 14, 2011 | 07:26 PM
C908's Avatar
C908
I went a head and followed your instructions on resetting the TPS before I left work tonight. I also cleared my codes last night per some earlier instructions.I only rode a few miles today but so far no issues. I will update if I have anymore information to share. I might add I'm really surprised this happened since I did not splice any wires but instead replaced the throttle sensor with a new one that has extended wires.
