Check Engine light came on today.
Old Sep 13, 2011 | 07:03 PM
C908's Avatar
C908
Default Check Engine light came on today.
Got on my bike today to go have lunch and the check engine light came on for the first time. I only rode a short distance and it was in the safety mode where I couldn't accelerate enough to shift into second. I pulled over and called my local dealer and he said you just changed your bars didn't you? I said yes but that was a couple weeks and 500 miles ago.He said probably something to do with your throttle sensor.I said I wouldn't think so since I replaced it with a new one that has the extended wires.Anyway after shutting the bike off and starting it back up everything seemed fine for the rest of my lunch ride.Went for about a 25 mile ride coming home and everything was still fine.Anyone have any ideas on what might have caused the check engine light to come on just this one time? I forgot to mention my bike is a 2010 Ultra Classic with 9500 miles. The only thing I have done is install Rinehart slipons on and everything else is stock.There has been no tune and the stock air cleaner has not been removed. I appreciate your comments. Thanks.
Old Sep 13, 2011 | 07:14 PM
Toypuller's Avatar
Toypuller
Did you pull the code?
Old Sep 13, 2011 | 07:19 PM
C908's Avatar
C908
Sorry I'm afraid I don't know how to pull a code, could someone please advise me. Thanks
Old Sep 13, 2011 | 07:25 PM
JTAY123's Avatar
JTAY123
5th Gear
Here is more data and info on how to retrieve the codes via the speedo readout:
The IM (instrument module) is capable of displaying DTC's (diagnostic trouble codes).
Speedometer Self Diagnostics: The speedometer is capable of displaying and clearing speedometer, tachometer, TSM/TSSM and ICM/ECM Diagnostic Trouble Codes (DTC).
1- Turn Ignition switch to OFF & Run/Stop switch is to Run.
2- Push odometer reset button in & hold.
3- Turn ignition switch to Ignition and release odometer reset button. Background lighting sould illuminate, speedometer needle should sweep its full range
and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word “diag” should then appear.
4 - Push the odometer reset button once and you will see the selection menu "PSSPt" with the first P flashing.
5 - Each letter represents an area of the diagnostics module. The module that is flashing is the one you are going to check. To move from one letter (module)
to the next, you push the odometer reset button one time. (from P to S to SP to t and back to P, etc.)
P = ECM/ICM (Electronic Control Module (EFI) / (Ignition Control Module, 'Carbureted')
S = TSM/TSSM (Turn Signal/ Turn Signal Security Module)
SP = speedometer
T = tachometer
6 - To get the DTC within an area of diagnostics, push and hold the odometer reset button in for 5 seconds and release. If there are any DTC’s the code will be
displayed or the word “none” will appear if there are no DTC’s. Push the odometer reset button again to view additional codes if they exist.
7 - Record the codes.
8 - If DTC’s are not to be cleared, Press and release the odometer reset button. Part number of module will be displayed.
NOTE: To determine if a code is current or historic, clear the displayed code by pushing in and holding the odometer reset button ( longer than 5 seconds) until 'clear' comes up.
Release the odometer reset button. Turn OFF the ignition switch. Run your bike and shut it down then recheck the DTC’s again by repeating steps 1 to 9.
If the code is current it will reappear.
9 – Press and release the odometer reset button to continue to the next module.
10 – Turn Ignition switch to OFF.
DTC FAULT CONDITION MODULE
B0563 Battery Voltage High TSM/TSSM
B1004 Fuel Level Sending Unit Low Instruments
B1005 Fuel Level Sending Unit High/Open Instruments
B1006 Accessory Line Overvoltage Instruments
B1007 Ignition Line Overvoltage Instruments
B1008 Reset Switch Closed Instruments
B1131 Alarm Output Low TSM/TSSM
B1132 Alarm Output High TSM/TSSM
B1134 Starter Output High TSM/TSSM
B1135 Accelerometer Fault TSM/TSSM
B1151 Sidecar BAS Low TSM/TSSM
B1152 Sidecar BAS High TSM/TSSM
B1153 Sidecar BAS Out of Range TSM/TSSM
P0106 MAP Sensor Rate of Range Error Carb
P0107 Map Sensor Failed Open/Low Carb
P0107 Map Sensor Open/Low EFI
P0108 Map Sensor Failed High Carb
P0108 Map Sensor High EFI
P0112 IAT Sensor Voltage Low EFI
P0113 IAT Sensor Voltage Open/High EFI
P0117 ET Sensor Voltage Low EFI
P0118 ET Sensor Voltage Open/High EFI
P0122 TP Sensor Open/Low EFI
P0123 TP Sensor High EFI
P0261 Front Injector Open/Low EFI
P0262 Front Injector High EFI
P0263 Rear Injector Open/Low EFI
P0264 Rear Injector High EFI
P0373 CKP Sensor Intermittent Carb
P0373 CKP Sensor Intermittent EFI
P0374 CKP Sensor Not Detected Carb
P0374 CKP Sensor Synch Error EFI
P0501 VSS Low Carb
P0501 VSS Low EFI
P0502 VSS High/Open Carb
P0502 VSS High/Open EFI
P0505 Loss of Idle Sped Control EFI
P0562 Battery Voltage Low Carb
P0562 Battery Voltage Low EFI
P0563 Battery Voltage High Carb
P0563 Battery Voltage High EFI
P0602 Calibration Memory Error Carb
P0603 EEPROM Failure Carb
P0603 ECM EEPROM Error EFI
P0604 RAM Failure Carb
P0605 Program Memory Error Carb
P0605 ECM Flash Error EFI
P0607 Converter Error Carb
P1001 System Relay Coil Open/Low EFI
P1002 System relay Coil High/Shorted EFI
P1003 System relay Contacts Open EFI
P1004 System Relay Contacts Closed EFI
P1009 Incorrect Password Carb
P1009 Incorrect Password EFI
P1010 Missing Password Carb
P1010 Missing Password EFI
P1351 Front Ignition Open/Low Carb
P1351 Front Ignition Open/Low EFI
P1352 Front Ignition Coil High/Shorted Carb
P1352 Front Ignition Coil High/Shorted EFI
P1353 Front Cylinder No Combustion EFI
P1354 Rear Ignition Coil Open/Low Carb
P1354 Rear Ignition Coil Open/Low EFI
P1355 Rear Ignition Coil High/Shorted Carb
P1355 Rear Ignition Coil High/Shorted EFI
P1356 Rear Cylinder No Combustion EFI
P1357 Intermittent Secondary Front EFI
P1358 Intermittent Secondary Rear EFI
U1016 Loss of ICM/ECM Serial Data Instruments
U1016 Loss of ECM Serial Data, Vehicle Speed, Vehicle Inhibit Motion or Powertrain Security Status TSM/TSSM
U1064 Loss of TSM/TSSM Serial Data Carb
U1064 Loss of TSM/TSSM Serial Data EFI
U1064 Loss of TSM/TSSM Serial Data Instruments
U1097 Loss of Speedometer Serial data Carb
U1097 Loss of Speedometer Serial data EFI
U1097 Loss of Speedometer Serial data TSM/TSSM
U1255 Missing Message at Speedometer EFI
U1255 Serial Data Error/Missing Message EFI
U1255 Serial Data Error/Missing Message Instruments
U1255 Serial Data Error/Missing Message TSM/TSSM
U1300 Serial Data Low Carb
U1300 Serial Data Low EFI
U1300 Serial Data Low Instruments
U1300 Serial Data Low TSM/TSSM
U1301 Serial Data Open/High Carb
U1301 Serial Data Open/High EFI
U1301 Serial Data Open/High Instruments
U1301 Serial Data Open/High TSM/TSSM
AFR – Air Fuel Ratio
ATS – Air Temperature Sensor
BAS – Bank Angle Sensor
CCM – Cruise Control Module
CKP – Crank Position Sensor. The CKP generates an “AC signal” which is sent to the ECM where it is used to reference engine position (TDC) and speed.
DTC – Diagnostic Trouble Codes
Old Sep 13, 2011 | 07:28 PM
jmorganroadglide's Avatar
jmorganroadglide
Big Kahuna HDF Member
Had problems with my 2010 Road Glide on a road trip. It wouldn't accelerate at all. The check engine light did not come on however. I unplugged the harness on the rear of the air cleaner, shoved on the pins with a knife, plugged it back in and the bike ran for a few miles. Had the bike hauled to Thunderbird Harley in Albuquerque, NM. by TJ's Motorcycle taxi service. Was a broken wire in the harness that the dealer repaired under warranty. Still think I will try to get a new harness installed now that I am home. Bike did run for 4200 trouble free miles after that. Kudo's to Thunderbird Harley for getting me in and fixed while on the road. TJ's Motorcycle Taxi Service was professional and timely. TJ's charged $216 for coming out 42 miles to get the bike and take it to the dealer. I thought that was reasonable and he took great care with my bike. There is a harley tech tip #415 [I think] that talks of using some kind of grease on some of the throttle by wire connectors.
Old Sep 13, 2011 | 07:51 PM
18BKLR's Avatar
18BKLR
Same thing happened to me after a handlebar install. I fired it up in the garage for a warm up and no throttle. Here is my handle on it. After playing with the bars and unhooking things I would say I might have turned on the ignition without something hooked up. Therefore I stored a code in the system and never cleared it. After mine did it I hooked up with the computer and say that it was in fact a historic code and cleared it. Been riding it ever since and it has never come back. Might be your situation as well. These stupid things are smarter than we think.
Old Sep 13, 2011 | 09:39 PM
smithbrl's Avatar
smithbrl
Mine has had problems with this 4 times. I'll take off in 1st gear and when I get up to about 15 mph it flattens out and wont go any faster. I shift to 2nd and crank the throttle. It accelerates normally after that like there is no problem. It throws codes P1510, P2127 and P2138 every time. Sometimes the CEL comes on and sometimes it doesn't. It all started after I changed my bars but it's been to the dealer 3 times and when I get it back it is normal for a while but the problem keeps returning. I suspect it's the grip sensor but they've replaced it. I can't remember if they replaced the pins in the plug at the throttle body. I've wiggled the plug with the bike running and couldn't duplicate the problem.
Old Sep 13, 2011 | 11:07 PM
C908's Avatar
C908
SP = speedometer
T = tachometer
P0501 VSS Low Carb
P0501 VSS Low EFI
I followed the instructions above and was able to pull two codes P1511 and P2135. Anyone know what these are ? I do not see them on the list of codes. I cleared them and restarted my bike and then shut it down and rechecked for codes and in place of codes it came up showing clear. Any thoughts? Thanks for your comments.
Old Sep 14, 2011 | 01:19 AM
Dr. Tiki's Avatar
Dr. Tiki
P1511 EFI Power Management Mode
P2135 TPS Correlation Error
This is the list of codes that I have saved:
B1121 (TSM) Left Turn Output Fault - (HFSM) Left Turn Output Open
B1122 (TSM) Right Turn Output Fault - (HFSM) Right Turn Output Open
B1123 (HFSM) Left Turn Output Short to Ground
B1124 (HFSM) Right Turn Output Short to Ground
B1125 (HFSM) Left Turn Output Short to Battery
B1126 (HFSM) Right Turn Output Short to Battery
B1131 (HFSM) Alarm Output Low
B1132 (HFSM) Alarm Output High
B1136 (HFSM) Accelerometer Tip Test Error
B1141 (TSM) Ignition Switch Low/Open - (HFSM) Ignition Switch Low/Open
B1142 Smart Security System Internal Fault
B1143 (HFSM) Security Antenna Short to Ground
B1144 (HFSM) Security Antenna Short to Battery
B1145 (HFSM) Security Antenna Open
B1151 Bank Angle Sensor(BAS) Short to Ground
B1152 Bank Angle Sensor(BAS) Short to Battery
B1153 Bank Angle Sensor(BAS) High
B1154 Clutch Switch Input Short to Ground
B1155 Neutral Switch Input Short to Battery
P0112I AT Voltage Low
P0113I AT Sensor Voltage Open/High EFI
P0113I AT Voltage Open/High
P0117 ET Sensor Low
P0118 ET Sensor High
P0120 TPS1 Range Error
P0122 TPS1 Low
P0123 TPS2 High/Open
P0131 Front Oxygen Sensor Low
P0132 Front Oxygen Sensor High
P0134 Front Oxygen Sensor Inactive
P0151 Rear Oxygen Sensor Low
P0152 Rear Oxygen Sensor High
P0154 Rear Oxygen Sensor Inactive
P0220 TPS2 Range Error
P0222 TPS2 Low
P0223 TPS2 High/Open
P0371 Crank Position Sensor (CKP)
P0372 Crank Position Sensor (CKP)
P0444 Purge Solenoid Open/Low
P0445 Purge Solenoid High
P0501 VSS Sensor Low
P0502 VSS High/Open
P0572 Brake Switch Low
P0577 Cruise Control Input High
P0603 ECM EEPROM Memory Error
P0605 ECM FLASH Memory Error
P06415 V+Vref 1 Out Of Range
P06515 V+Vref 2 Out Of Range
P1002 System Relay Coil High/Shorted
P1003 System relay contacts open
P1270 TGS Validation Error
P1351 Front Ignition Coil Driver Open/Low
P1352 Front Ignition Coil Driver High/Shorted
P1354 Rear Ignition Coil Driver Open/Low
P1355 Rear Ignition Coil Driver High/Shorted
P1357 Front Cylinder Combustion Intermittent
P1358 Rear Cylinder Combustion Intermittent
P1475 Exhaust Actuation Position Error
P1477 Exhaust Actuator Open/Low
P1478 Exhaust Actuator Shorted/High
P1501 Jiffy Stand Sensor Low
P1502 Jiffy Stand Sensor High
P1510 EFI Limited Performance Mode
P1512 EFI Forced Idle Mode
P1514 Air Flow Fault
P1600 EFI Module Processor Internal Error
P2100 EFI Motor Circuit Open
P2101 EFI Motor Circuit Range Performance (Actuation Error)
P2102 EFI Motor Circuit Low
P2103 EFI Motor Circuit High
P2105 EFI Forced engine shutdown
P2107 EFI Module Processor Internal Fault
P2119 EFI Motor Throttle Body Range Performance
P2122 TGS1 Low/Open
P2123 TGS1 High
P2127 TGS2 Low/Open
P2128 TGS2 High
P2138 TGS Correlation Error (Twist grip sensor)
P2176 EFI Closed Position Not Learned
U1016 Loss of ECM Vehicle Speed, Vehicle Inhibit Motion or Powertrain Security Status TSM/TSSM
U1064 Loss of TSM/FSFM Serial Data to ICM / ECM
U1097 Loss of Speedometer Serial Data to ECM
U1300 ECM Serial Data Low
Old Sep 14, 2011 | 07:34 AM
C908's Avatar
C908
Thanks for the answer on the two codes, does anyone know exactly what they mean ?
