Power Vision on Stage One RKC 103 DOES NOT WORK.
Old Sep 17, 2011 | 04:33 PM
Climb14er's Avatar
Climb14er
Default Power Vision on Stage One RKC 103 DOES NOT WORK.
Got it running! Sounds rich at idle. Three more heat/cool cycles. Hopefully weather will cooperate tomorrow, get 'er out on the road.
Old Sep 17, 2011 | 04:44 PM
Jim Dawson's Avatar
Jim Dawson
Uhh, did you send this to the forum by accident? Did you really mean to send it via email to Fuel-Moto?
Old Sep 17, 2011 | 04:55 PM
Climb14er's Avatar
Climb14er
I'll send Jamie a quick e-mail telling him that figured out most of the re-map.
Old Sep 17, 2011 | 05:01 PM
Teardrop's Avatar
Teardrop
Are you plugging the PV into the sockt under the left side cover?
Old Sep 17, 2011 | 05:06 PM
Morris9982's Avatar
Morris9982
This may sound silly but ensure you have it plugged into the ECM plug and not the accessory plug. They look very similar.
Old Sep 17, 2011 | 05:46 PM
Climb14er's Avatar
Climb14er
Thanks guys... Trying not to look too stupid! Spent the last five and a half hours getting everything taken off and installed. Maybe I'm a little tired at the last part of the Stage One.
Appreciated!
Old Sep 17, 2011 | 05:57 PM
skratch's Avatar
skratch
here is a pic of the cable plugged into my 2010. don't know if they've changed anything for 12, but this should give you an idea anyway.
Old Sep 17, 2011 | 06:03 PM
Climb14er's Avatar
Climb14er
Just found it! Thanks...
Going to flash the ecu and hoping for great results!
Old Sep 17, 2011 | 06:25 PM
Climb14er's Avatar
Climb14er
Fired 'er up... sounds rich at idle!
One aspect of the flash I did not see in the process.
Jamie said to put YES... where it prompted the following:
"Set and relearn fuel trims".
Is this in another part of the menu?
Thanks again!
Old Sep 17, 2011 | 07:28 PM
rscott's Avatar
rscott
comes up right after reflashing, I have power vision on my fltru 103in and have considerable spark plug pingn on hard acelleration after talking to Jamie He told me he would send me a version for my setup that I can load I will post results after I get it and load.
