When to replace rear tire
Old Nov 21, 2006 | 04:32 PM
dawg's Avatar
dawg
Default When to replace rear tire
I know it's better to be safe than sorry, and I know that the manual says as soon as you can see the tread wear bar you should change the tire, but I have about 6k miles on my rear tire and I can just start seeing and feeling the tread wear bar. These are the HD OEM Dunlops. I have also seen guys with tires in worse shape than me. What ya' all think, wait till next summer and go a little longer or replace now?
Old Nov 21, 2006 | 04:46 PM
rwagon57's Avatar
rwagon57
Default RE: When to replace rear tire
A long time ago when I worked in a metric shop in So Cal, a guy came into the shop walking next to his Goldwing idling along in 1st gear. He had a flat rear tire and he wanted us to patch the tube. The reason the tire was flat was that the tire was worn to the cord down the center all the way around and he had actually worn a hole through the tube. We told him, "no we can't patch the tube", so he said OK put in a new tube. We said, "no we can only help you by installing a new tire and new tube. Its for your safety." He asked if there was another shop nearby.
The moral is that this guy definitely took it too far. Just how far do you want to ride on a worn tire? If between now and next summer you will only rack up a couple hundred miles, wait, but if you bought it to ride get new rubber soon and ride.
Old Nov 21, 2006 | 05:27 PM
bountyhunter's Avatar
bountyhunter
Dawg, wait till after your motor work...do a big smokey burnout...THEN put on new rubber. Got my new rear 402 at Zanotti's for $115.
Old Nov 21, 2006 | 05:31 PM
dawg's Avatar
dawg
ORIGINAL: bountyhunter
Never thought of that! That sounds like a good plan I'm headed to R&R in Manchester, NH this Friday to chat with them about my plans
Old Nov 21, 2006 | 05:47 PM
Hdbiker1450's Avatar
Hdbiker1450
We've got 10,500 on our rear. Sure, it needs to be replaced, but I'm doing the wait till spring deal. 6,000 seems awfully low for your RK, you been doing lots of burn outs?
Old Nov 21, 2006 | 06:16 PM
rdam's Avatar
rdam
ORIGINAL: Hdbiker1450
I replaced mine at 10,000, and probably could have safely gotten another 1 or 2 K out of it, but was prepearing to leave for Laconia. 6K seems very low.
Hey BH, Is it legal to posess photos of guns in Canada?
Old Nov 21, 2006 | 06:25 PM
FLHTCUI05's Avatar
FLHTCUI05
Mine went 12000 on my 05 Ultra before I have to replace. Could have got a little more mileage but had a cut in the tire.
Old Nov 21, 2006 | 06:46 PM
04RoadKing's Avatar
04RoadKing
I'd wait
6000miles is not much at all. Unless you do alot of burn outs.
Old Nov 21, 2006 | 08:05 PM
Gutman's Avatar
Gutman
Hey Dawg, I like Bountyhunters plan. Tires should be replaced when their is 1/32" of tread depth remaining. A good way to check is with a penny. Hold the penny so Lincoln's head is upside down and place into center groove. The tread should protrude above Lincolns head. If level with Licoln's head, It's time to change. Go to www.dunlopmotorcycle.com, click on info center, then Minimum tread depth.
Old Nov 21, 2006 | 08:08 PM
DI75's Avatar
DI75
7500-10000 wether they need it or not. Blow out on a bike. NOT GOOD!![:@]
