Advice on EFI Controllers
Old Sep 21, 2011 | 03:51 PM
  #41
'05Train's Avatar
'05Train
Originally Posted by iclick
They are indeed great tools and I use one of them (PV), but this fact does not diminish the effectiveness of the PCV. I used a PCV for two years, the better part of that time with Auto-Tune, and it worked very well. I can tell no difference in normal operation between the tunes I achieved with one vs. the other. OTOH being able to alter idle speed, IAC steps, and a considerable number of other ECM parameters is truly useful for the advanced tuner. That said, most will not want or need that capability and don't fret over the details like you and I do .
Fair point, and I didn't mean to disparage the PCV. For the vast majority of people, I would recommend a PCV from Jamie, as most people (as you mention) aren't crippled with the level of tuning OCD that we are.
Old Sep 21, 2011 | 03:57 PM
  #42
iclick's Avatar
iclick
Indeed, but we're happy in our emotional disorderness .
Old Sep 21, 2011 | 05:16 PM
  #43
Brad&Mar's Avatar
Brad&Mar
1st Gear
Default Revtech vs. Commander fuel management?
I have an '05 FLHTCSE2. I want to know what the difference is between the Revtech vs. Commander fuel management system. Which do you perfer and why??
Also are there any other '05 FLHTCSE2 HD owners who have blown motors between 20,000 and 25,000 miles?
Any help???
Old Sep 21, 2011 | 09:25 PM
  #44
skydude426's Avatar
skydude426
[quote=iclick;8844081]Wow, I really don't know where to begin with this thread.
T'Max: Replaces the stock ECM and is a true auto-tuning device for AFRs, but not spark-advance. If this is a candidate, someone with more experience with T'Max will need to comment further on it. It is expensive at $700-800 (IIRC).
Timing is adjustable with T Max. It may be expensive to install a T Max but the savings down the line when you make changes to your bike must be considered. Its simple to use and will self tune to just about anything you do to your ride. My bike has never run better. It was money well spent. I'm sure a PCV would work well also. I just like the idea of tuning the ECM and not changing the output of the ECM with a piggy back device.
Old Sep 22, 2011 | 04:31 AM
  #45
'05Train's Avatar
'05Train
Timing is adjustable, but it doesn't auto-tune. Additionally, you're replacing the robust stock ECM with a product that isn't constructed as well, and you're losing the ion knock sensor.
Old Sep 22, 2011 | 10:41 AM
  #46
djl's Avatar
djl
Actually, you can have both in one map or tune. Mileage is largely a function of the tune in the cruise range and performance is affected most by throttle-positions above that. The only downside to a "mileage tune" is that it may run a bit hotter, as ideally you would tune WOT for maximum performance. You aren't at WOT often, at least I'm not, and when you nail it you want maximum performance as a safety issue if nothing else.
You say you can have it all in one map or tune but then contradict yourself by saying there is a downside to a mileage tune; so you really can't have both.
Not to disparage the Dobeck, but IIRC it only adjusts fuel in a positive direction. At $245 you could spend $55 more and have a PCV that will tune AFRs ą100% and spark advance ą10%, as well as provide many more features.
Plus another $300 for dyno time, each and every time performance modifications are made.
They are? Let's see, all flash-based tuners are "load-based" if it is indeed configured in the ECM as such. My '07 uses throttle-based VE tables, for example, although newer bikes have gone to KPA. I'd like to see evidence that a throttle-based tuner like the PCV will diminish the performance of any bike compared to a KPA-based strategy. Keep in mind the ECM will still work with the MAP and other sensors just as before. I am running PV (flash-based) and in terms of normal operation I sense no change in performance over the PCV and PCV-AT system I ran before this. It's all in the tune.
None of my posts have attempted to compare the Dobeck unit to "flash" tuners. IIRC, all the "fueler" tuners that are direct competitors to the Dobeck unit are throttle based. IMHO, with a fueler tuner, adding or taking away fuel based on load makes more sense than on throttle position.
I've seen "$1000" thrown about here more than once, but I know of no tuner that costs anywhere near this much in a real-world scenario. Why buy a $245 tuner than will only allow positive change in fuel delivery when you could buy a $300 tuner (PCV) that will go plus and minus for both fuel and spark-advance, is tunable on a dyno, and will provide many other useful features?
There are several simple answers, which I have made reference to several times in this thread.
1. Buying the $300 tuner, pre-mapped for a particular combination of performance upgrades, most of the time, will require a $300 dyno tune to get it right. So, the $300 tuner actually cost $600, plus the time and inconvenience some must go through to find a competent tuner.
2. There are not any other fuel management systems that can be purchased for $300. The TTS, SERT, TMax, Rev Performance, etc. can cost as much as $800+. Add the installation (if you are not a DIY guy) and a tune and you have spent at least $1000.
3. There are those that are quite content with a Stage I upgrade and a system like the Dobeck DFO/TFI is cheap, easy to intall, great customer service and the end user can tune to his/her hearts content.
Guys like you and Train that are **** about tuning sometimes see things from a completely different perspective than a guy that is not interested in optimiizing performance and just wants a basically stock bike that gets decent mileage, starts easy, has an authoritative exhaust note that doesn't burp, fart or pop. Those guys can do that with the Dobeck unit and if the shop Ebay, they can find one for $175-$200 from guys that have "graduated" to a more sophisticated system. If they want to spend a little more and upgrade to the Gen 4, they can even check AFR. Who knows, once they start that, they might develop the same OCD that posseses you.
I mean no disrespect to you or Train and I whole heartedly agree, in principle, with everything you guys have posted. However, not everyone has the same perspective that you guys do. As a matter of fact, I am envious because I have not acquired the tuning skills that you guys have. I am a gear head, for sure but tuning is not a skill I have attempted to master. I run a SERT on my 95" Deuce but my 107" FLHT is carbed. I have plans to upgrade my SERT to the TTS before I instlall the 120R kit in the Deuce. I have the manual and an experienced tuner has offered to help me learn, so maybe some day Iwill acquire tuning skills. However, that will not change my mind that there is a place for a unit like the DFO with a certain segment of the Harley population. I think it is important for those that are interested to know that there is a viable DIY alternative to the more sophisticated and more expensive fuel management systems for those that don't want or need them.
BTW, anyone that does use the Dobeck system can find beaucoup information on the systems and what settings others are using on the HDTalking forum.
Old Sep 22, 2011 | 11:53 AM
  #47
lionsm13's Avatar
lionsm13
I disagree with #1.
I bought my pre-mapped PC-V from F/M , and it was good to go right outta the box. Run fantastic!! I don't feel that I was the exception either.
Never once did I think about a tuner...to establish a map...it run that good.
Now though since I have changed cams and added an autotuner, I am messing with it, but still do not want to take it to a tuner as of yet..
Old Sep 24, 2011 | 12:13 AM
  #48
iclick's Avatar
iclick
There's no contradiction at all in the intent of my reply. If you'll go back and read the statement to which I was responding, I was saying that you don't have to sacrifice mileage for performance, and it is true that you can have both in one tune or map. The compromise lies with heat generated, but with my bike the difference between 13.5:1 and 14.6:1 in the cruise range amounts to very little heat increase measured at the front head and none in oil temperature.
To be more specific, the idea is to lean the cruise range and leave the heavy-throttle calibration as is. Leaning WOT wouldn't make much sense, IMO, as who is riding in the range enough to make a difference in mileage with an AFR calibration that doesn't optimize performance? It also wouldn't make sense because you need maximum performance at WOT, not a compromise in safety for a miniscule amount of mileage improvement.
You can get map upgrades from Fuel Moto for many configurations, so unless you have an odd combination of hardware in your upgrade you will likely not need a dyno tune.
In theory it may be the preferred method, but in practice I'm not sure it makes much difference. I ran a PCIII, PCV, PCV-AT, and now PV--and I can't say that in terms of general performance that there is any difference that can be sensed. I changed to the flash-based tuner to get the display unit and the ability to make adjustments in ECM parameters I couldn't alter before. I'll wager that most riders aren't interested in adjusting IAC steps, warm-up AFR, etc. and just want a good-running bike.
In 16 years of riding Harleys I've never had a dyno tune on any one of them. Could I have squeezed another few HP or ft-lbs. by doing so? Possibly, but I'm not sure I would've noticed the difference in my butt dyno. If maximizing HP and TQ is the goal I'll agree that a dyno tune may be needed, but most aren't interested enough to spend a few $C more for that luxury. I certainly wouldn't denigrate anyone for aspiring for peak performance at a high price, but it isn't my goal.
All true, and you can add the PCV-AT to that elite group. T'Max and PCV-AT likely will not need a dyno tune, as they will both auto-tune AFRs throughout the RPM range. Spark advance is another matter, but it can be tweaked by ear contrary to popular belief given a close calibration, and the PV will tune spark advance using its proprietary software. It is the only tuner that I know of that will do this, and with the AT-100 auto-tune kit you can tune AFRs and spark advance without a dyno tune. Cost? About $800, which certainly puts it in the realm of the elite tuners in terms of cost, but IMO you can do it all with the Power Vision. Rev Performance appears to be a good device but I understand the user is out of the picture as regards tuning.
I can't comment on the Dobeck since I have no experience with it, but I understand its functionality is shallow.
I don't know about Train, but I'm not interested in optimizing performance to the very last 1/10 of a HP. My feeling is that if I get it within a HP/TQ or two I won't be able to discern any difference. For example, about a year ago I moved from the Jackpot standard to the quiet baffle, which by Fuel Moto's tests results in a small TQ and HP reduction, but I didn't feel any difference. At the time I was using the PCV-AT.
Woe be he who falls into that trap.
Well, not to be defensive, but if you'll read every post I've made about tuners I make it quite clear that there is no "best" tuner for every rider, and I've never touted any tuner as such. I do think the PCV from FM is the best option for many riders simply because it works and FM's maps are accurate with a database that covers a plentiful array of applications both stock and modified. I think this variable is very important in the equation.
Well, thanks for the compliment--but my tuning skills, at whatever level they may currently fall on, are a product in the making. I'm getting there but there's much to learn. I was using the PCV-AT and was getting to know that tuner quite well, I think, and so I just naturally had to move on. "If it ain't broke don't fix it" certainly applies here, but I'm still fixing what was never broken and getting some good mental exercise in the process. Now with the PV it is another world delving into ECM functions and parameters.
BTW, I didn't intend to denigrate the Dobeck, as I know little about it, but simply say that for another $55 you could have a PCV from FM. IMO that's a better bargain by any objective measure. Indeed, even the simple IED (and its variants) may have a niche in this market, although they certainly aren't even tuners. I'll admit that they have a place, but at $150 I don't see these as a bargain for most riders, as most will likely outgrow their capabilities.
Thanks for all your thoughts. Good discussion!
Old Sep 24, 2011 | 01:19 AM
  #49
cruzmisl's Avatar
cruzmisl
Originally Posted by lionsm13
What are you running as far as temps go cruzmisl w/the rev. per.?
Not sure. Its "cooler" than it was from the factory but the weather is also changing here too so its tough to estimate. Is there a method to test it or is it all a guess?
Old Sep 24, 2011 | 06:49 AM
  #50
lionsm13's Avatar
lionsm13
An oil temp gauge generally works fairly well.
