Right now I have a sert. the draw back is my bike always has to run on the current tune which is tuned for nitrous.
I've been looking at some options. It seems either the pcv which has a switch to go between tunes on the fly or dobeck's tfi tuner that has a lead on the unit that goes to the nos. when the button is hit it picks up voltage to the nos and automaticly throws more fuel.
Does anybody have any input on these systems or any other tuner I should consider ?
I use a PCV with 2 maps from Fuelmoto. I can switch on the fly from their standard map to the economap. I used a relay and wired it up through the ACC switch on the Ultra. The Power Vision will hold 6(?) maps, but I believe you must stop/shutdown/switch maps/startup.
