engine performance
Old Sep 23, 2011 | 09:32 AM
CT-Bagger's Avatar
CT-Bagger
Throttle body might need a cleaning and light lube.
Old Sep 23, 2011 | 09:36 AM
billhd1's Avatar
billhd1
I am going to try all these ideas that you all have helped me with. It is nice to know that there are real bros out there that care enough to try to help. I will get back to you all as soon as I can but I must go into the garage and start all these ideas. Thanks to you all. Have a great morning. Bill
Old Sep 23, 2011 | 12:22 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
IAC. Idle air control. Ultra has a good description on it. It has a solenoid controlled v pintol valve that let air in and back to a hole behind throttle valve flap. You can see in jump in and out on key on/motor. Not keen in all that spray. May drive all way up into solenoid and kill it later. Just spray lightly with it open (key on-motor off) while you hold throttle wide open. You will see spray come out air hole behind plate. Its just an air hole. No difference than idle up with throttle except ECM is controlling it.
Old Sep 23, 2011 | 01:21 PM
UltraNutZ's Avatar
UltraNutZ
oh yeah.. forgot about twisting the throttle. LOL.. never gonna see that hole if you don't twist the throttle. :-)
Old Sep 23, 2011 | 03:18 PM
'05Train's Avatar
'05Train
It's a 2001 with the old MM fuel injection. I've got nothing on that system, but I'd start with the basics....Fresh gas, fuel filter, plugs. Clean the throttle body and make sure the air cleaner element is in good shape.
Old Sep 23, 2011 | 03:28 PM
mrmud4x4's Avatar
mrmud4x4
+1 on changing the fuel filter and fresh fuel...and also add some good fuel cleaner to the fuel. 1/2 can of Seafoam fuel cleaner per tank full. That will really help clean out the fuel system. Amsoil makes a quality fuel cleaner also.
Fuel filter is inside the fuel tank.....
Did that to my RK and it actually made it harder to hear the fuel pump when turning the ignition on.
Bought a nice Honda VTX for my son......was stored for about 4 years...real low miles...ran like crud...Seafoam and 2 tanks cleaned it right up...ran good after that.
+1 on the IAC also..
Old Sep 23, 2011 | 05:29 PM
classic53's Avatar
classic53
Another thing to possibly check are the intake gaskets. Stored 4 years and no moisture whatsoever on those puppies could have dried them out.
Old Sep 23, 2011 | 06:11 PM
kingkingking's Avatar
kingkingking
Definitely IAC -Idle air control..
Its a solenoid bypass of the throttle plate. The throttle plate closes and the IAC is like a mini throttle plate that the computer can vary to control the amount of air going into the motor at low rpms precisely. it is probably gummed up with crud.
Old Sep 26, 2011 | 07:39 AM
billhd1's Avatar
billhd1
I have changed everything and still the same problem. I guess I will have to take it to the steelers for a scan??? I am going to try the fuel pressure regulator first??? This is the only thing left to do
Old Sep 26, 2011 | 08:39 AM
UltraNutZ's Avatar
UltraNutZ
did you clean the IAC through the pintol? if so, it may have simply failed but if it did, you should be able to pull a code from the bike's speedo
1. Remove right side saddlebag and side cover if so equipped. Remove protective plug from data link connector.
2. To activate the diagnostic feature, proceed as follows:
a. Create diagnostic test wire or use a female spade clip.
b. Install diagnostic test wire across Terminals 1 and 2 on the data link connector.
c. Turn Ignition/Light Key Switch to IGNITION and wait approximately 10 seconds (4 seconds lamp ON, 6 seconds lamp OFF) for check engine lamp to start flashing.
3. All trouble codes are sent out as a series of flashes. To retrieve the first digit of the trouble code simply observe the number of times the lamp flashes.
a. The lamp will then flash one or more times to indicate the first digit of the trouble code.
b. The length of time the lamp is illuminated and the length of time in which it is off are each about 0.5 second in duration.
4. The second digit follows:
a. Following the transmission of the first digit, there is a 1.2 second pause in which the lamp is off.
b. The lamp will then flash one or more times to indicate the second digit of the trouble code. Count the number of times the lamp flashes to retrieve the second digit.
5. If more than one trouble code is sent:
a. Following transmission of the second digit of the first code, there is a 3 second pause in which the lamp is off.
b. Once all codes have been sent, the data string is repeated. When you have recorded the same trouble code twice, it is an indication that the transmission has been restarted and that all trouble codes have been retrieved.
IMPORTANT NOTE ..If diagnostic test wire is installed across Pins 1 and 2 on connector in lieu of a Scanalyzer, the ECM is placed in a diagnostic test mode and the engine will start. The test wire must be removed from the data connector and the ignition switch turned OFF or the check engine lamp will continue to flash codes. A historic trouble code resides in the memory of the ECM until the code is cleared by use of the Scanalyzer or a total of 50 trips has elapsed. A “trip” consists of a start and run cycle, the run cycle lasting at least 30 seconds. After the 50 trip retention period, the trouble code is automatically erased from memory (that is, assuming no subsequent faults of the same type are detected in that period). The numbers after the 'historic' or 'current' is the speedo code number, but without the electrical diognostics manual you're peeing into the wind.
1 Current 53 ECM flash error
2 Historic 53 ECM flash error
3 Current 54 ECM EEPROM error
4 Historic 54 ECM EEPROM error
5 Current 63 ECM serial data low
6 Current 63 ECM serial data open/high
7 Current 63 TSSM serial data low
8 Current 63 TSSM serial data open/high
9 Current 61 Loss of TSM/TSSM serial data
10 Current 14 Loss of all ECM serial data (state of health)
10 24 Loss of vehicle speed
10 33 Loss of vehicle inhibit motion
10 43 Loss of power train security status
11 Current 33 System relay contacts open
12 Current 33 System relay coil high/shorted
13 Current 33 System relay coil open/low
14 Current 33 System relay contacts closed
15 Current 99 Incorrect password
16 Current 99 Missing password
17 Current 41 CKP sensor intermittent
18 Current 41 CKP sensor synch error
19 Current 11 TP sensor open/low
20 Current 11 TP sensor high
21 Current 12 MAP sensor open/low
22 Current 12 MAP sensor high
23 Current 14 ET sensor voltage low
24 Current 14 ET sensor open/high
25 Current 15 IAT sensor voltage low
26 Current 15 IAT sensor open/high
27 Current 24 Front ignition coil open/low
28 Current 25 Rear ignition coil open/low
29 Current 24 Front ignition coil high/shorted
30 Current 25 Rear ignition coil high/shorted
31 Current 24 Front cylinder combustion intermittent
32 Current 25 Rear cylinder combustion intermittent
33 Current 23 Front injector open/low
34 Current 32 Rear injector open/low
35 Current 23 Front injector high
36 Current 32 Rear injector high
37 Current 16 Battery voltage low
38 Current 16 Battery voltage high
39 Current 43 VSS sensor low
40 Current 43 VSS sensor high
41 Current N/A (no speedo code for this) Check engine light open/low NO CHECK ENGINE LAMP AT KEY ON or CHECK ENGINE LAMP ON CONTINUOUSLY
42 Current N/A (no speedo code for this) Check engine light high NO CHECK ENGINE LAMP AT KEY ON
43 Current 35 Tachometer low
44 Current 35 Tachometer high
45 Current 25 Rear cylinder no combustion
46 Current 24 Front cylinder no combustion
47 Current 34 Loss of idle speed control IDLE AIR CONTROL
48 Current 35 Accelerometer fault
49 Current 34 Starter output high
50 Current 25 Ignition enable output high
51 Current 21 Left turn output fault
52 Current 22 Right turn output fault
53 Current 11 Battery voltage high
54 Current 31 Alarm output low
55 Current 32 Alarm output high
56 Current 41 Ignition switch open/low
57 Historic 63 ECM serial data low
58 Historic 63 ECM serial data open/high
59 Historic 63 TSSM serial data low
60 Historic 63 TSSM serial data open/high
61 Historic 61 Loss of TSM/TSSM serial data
62 Historic 14 Loss of all ECM serial data (state of health)
63 Historic 33 System relay contacts open
64 Historic 33 System relay coil high/shorted
65 Historic 33 System relay coil open/low
66 Historic 33 System relay contacts closed
67 Historic 99 Incorrect password
68 Historic 99 Missing password
69 Historic 41 CKP sensor intermittent
70 Historic 41 CKP sensor synch error
71 Historic 11 TP sensor open/low
72 Historic 11 TP sensor high
73 Historic 12 MAP sensor open/low
74 Historic 12 MAP sensor high
75 Historic 14 ET sensor voltage low
76 Historic 14 ET sensor open/high
77 Historic 15 IAT sensor voltage low
78 Historic 15 IAT sensor open/high
79 Historic 24 Front ignition coil open/low
80 Historic 25 Rear ignition coil open/low
81 Historic 24 Front ignition coil high/shorted
82 Historic 25 Rear ignition coil high/shorted
83 Historic 24 Front cylinder combustion intermittent
84 Historic 25 Rear cylinder combustion intermittent
85 Historic 23 Front injector open/low
86 Historic 32 Rear injector open/low
87 Historic 23 Front injector high
88 Historic 32 Rear injector high
89 Historic 16 Battery voltage low
90 Historic 16 Battery voltage high
91 Historic 43 VSS sensor low
92 Historic 43 VSS sensor high
93 Historic N/A Check engine light open/low NO CHECK ENGINE LAMP AT KEY ON or CHECK ENGINE LAMP ON CONTINUOUSLY
94 Historic N/A Check engine light high NO CHECK ENGINE LAMP AT KEY ON
95 Historic 35 Tachometer low
96 Historic 35 Tachometer high
97 Historic 25 Rear cylinder no combustion
98 Historic 24 Front cylinder no combustion
99 Historic 34 Loss of idle speed control
100 Historic 35 Accelerometer fault
101 Historic 34 Starter output high
102 Historic 25 Ignition enable output high
103 Historic 21 Left turn output fault
104 Historic 22 Right turn output fault
105 Historic 11 Battery voltage high
106 Historic 31 Alarm output low
107 Historic 32 Alarm output high
108 Historic 41 Ignition switch open/low
