Roadking wobble
Old Nov 25, 2006 | 09:57 PM
bagga's Avatar
bagga
Default RE: Roadking wobble
if you have spokes check for loose ones. start with the rear wheel.
Old Nov 25, 2006 | 10:03 PM
Longtimegone's Avatar
Longtimegone
No wobble.
Old Nov 26, 2006 | 02:58 PM
xldme's Avatar
xldme
Had a slight wobble on my 2003 Road King on take offs. The dealer said it was the front tire, it had a feathered edge on one side of it. Replaced tire and wobble was gone. At high speeds no wobbles ever.
Old Jan 30, 2007 | 10:46 PM
06POLICE's Avatar
06POLICE
April 06 bought new road king police.... 110 NO WABBLE
Old Jan 30, 2007 | 11:27 PM
Arizona's Avatar
Arizona
I've also heard of it being caused by loose spokes...
Old Jan 30, 2007 | 11:28 PM
SLORider's Avatar
SLORider
We wobble but we don't fall down.
Your buddies knowledge is suspect. Given the right circumstances any motorcycle can wobble. As they come from the factory Road Kings are not any more prone to it than other bikes. JMO (I'm not that humble)
Old Jan 31, 2007 | 05:21 AM
GMONEY220's Avatar
GMONEY220
110No wobble(with and w/outaftermarket fairing on).However,on the grooved highways you get it sparringly at different speeds on any bike i believe.
Old Jan 31, 2007 | 05:46 AM
vegashd's Avatar
vegashd
ORIGINAL: GMONEY220
no kidding.... especially with all this crap construction around here
Old Jan 31, 2007 | 05:48 AM
mtuck318's Avatar
mtuck318
I had an 02 FLHPI. Now have 07 RG. No wobbble to 115. However, tire cupped or out of balance would be first check. On a bike with mileage, second check would be swing arm bushing / torque bolts. Third, motor mount. Fourth, sterring head bearing torque. Fifth, suspension check. Last, alignment of wheels and motor. These are normal maintenance checks. I would do all the above for the propermaintenance of any motorcycle.
Old Jan 31, 2007 | 07:22 AM
Fearless1's Avatar
Fearless1
99 roadking here and I get wobble at higher speeds passing cars when I cross the center line and at higher speeds around corners I will start checking spokes tire pressure and neck bearings. Anyone got info on the stearing dampners?
