Part # for rear stop light switch?
Old Sep 28, 2011 | 11:15 PM
imskier2's Avatar
imskier2
Default Part # for rear stop light switch?
Dawg do you or anyone have a pert # for the rear brake light switch on a 2009 Ultra, Thanks in advance.
Old Sep 29, 2011 | 01:03 AM
mkguitar's Avatar
mkguitar
it's here:
http://partsfinder.onlinemicrofiche....=13&A=666&B=24
it's a pretty good resource, select the part put it in the 'shopping cart' part numbers are revealed at check out and you can buy from Ronnies or your other favorite online dealer.
you can back up through the index and they have parts fiche for most models the past 20 years.
mike
Old Sep 29, 2011 | 06:03 AM
HDV-GLIDE's Avatar
HDV-GLIDE
76023-51d
Old Sep 29, 2011 | 06:23 AM
HDV-GLIDE's Avatar
HDV-GLIDE
me bad..typo.....yes on the 72023-51D
Old Sep 29, 2011 | 06:25 AM
shortride's Avatar
shortride
2009 Ultra Classic rear stop light switch - 72023-51D
I just replaced mine.
Old Sep 29, 2011 | 11:38 AM
imskier2's Avatar
imskier2
Thank to both of you for your timley part info off to the dealer I go with correct info in hand...
P.S. I like your choice of bike colors...
Old Sep 29, 2011 | 12:09 PM
Damascus's Avatar
Damascus
You may want to try this heavy duty one below. I have it on order after getting recommendations here. My thoughts are replacing a stocker with a stocker will only fix the problem for a while.
Also ... even after reading a bunch of threads on the matter ... I can't tell if the failure is due to the switch itself, or the fix is simply to wrap it with some heat shield.
Any thoughts???
Qty
Item No
Description
ACCEL HYDRAULIC BRAKE SWITCH
hdmc01
Oct 3, 2022 04:43 PM
dab102999
Oct 12, 2017 11:35 AM
cpt373
May 9, 2011 12:54 PM
edfromptowne
Electrical/Lighting/Alarm
Nov 5, 2009 07:00 PM
dert
Sep 12, 2005 11:06 AM
