When I priced the HD and Gerbing controllers last week, they were both the same price ($199) but the HD came with a pouch with clip and the Gerbing didn't.
Is Canada that much more or is it the exchange rate? I remember buying a jacket for the wife and one for me last Christmas. Got two duel controlers for $80 each because we bought the jackets. I thought they were about $100 normally. Granted no pouch, but so far I just tuck it in the top of my chaps while riding.
Sorry, my bad! I was quoted $99.95 for a Gerbing controller in the US and paid $100 for the HD one with the pouch. So much money flying out of the wallet lately, I guess it just seemed like another hundred bills gone LOL! Actually bought the controller in Maine a couple of weeks ago. For a while our dollar was up to almost $1.10 US so after Deeley took their grab we only were paying about 10% above US prices. Almost made it worthwhile to buy local. I paid $35 above US cost for the gloves here but they had them in stock at our local dealer where I could try them on to see what size I wanted whereas in Bangor they'd have to order them. Now our currency is plunging again ($0.945 today) so I expect we'll see Deeley raising prices across the board if it doesn't soon rebound.
I think your on to a good solution although safety pins might work to. You could also have a seamstress sew some loops or tabs to the inside of your jacket to attach things to. The lady at my local dry cleaner will do this kind of thing for $10-$20 which is probably typical most places.
I find what works best is to simply leave everything attached to the jacket when it gets hung up in the closet. When I go riding I only have the one wire, the power lead, to connect to the bike. I'm not a big fan of mounting the controller permanently to the bike unless it is a wireless variety like FirstGear/Warm&Safe make. Why? Because it is easy to get off the bike without remembering to unplug so if you have two leads going to the bike there is more of a chance of something breaking. It is important to be able to make heat adjustments while riding, something you can't do with a controller stuffed in the pocket of a jacket.
I think I'm going to end up doing something like that to secure the wiring inside the jacket. Even with a wireless controller, for sure you would still be tethered to the bike by the main power cord to the heating elements. Can't see a way to get around that.
The best heat controller is the remote one by Warm and Safe. The sender unit stays tucked away in a pocket in the jacket, and the control unit can be velcro-mounted anywhere you want on your bike. No wires hanging out and the controller is in plain view where you want it. Especially convenient if you have more than one bike as it's a cinch to move the control unit.
Yabbut - I already bought the HD/Gerbing one. Wish I knew this before and was able to find a place within driving distance to have a look at one. Next priority is a liner before changing the controller.
After years of snaking wires down my sleeves and having them ride up my arm and doing the shakee dance to get them back where they belong, I decided to solve that issue. I got rid of the expensive controller which will fail at a time you really need it, and went with the simple on/off switch. I wasn't sure if I would be turning it on and off all the time, but found I didn't have to. Then I ty wrapped the wires to the bars instead of running them down my sleeves, leaving enough slack to plug in the gloves and manuver . When you get off the bike, unplug your gloves and the wiring stays. Then in the spring, I remove the ty wrapped wires and put them away until next fall. I just use the gloves tho.,,
Now that's a different approach. Sure as hell I'd end up getting the leads tangled in my brake or clutch levers though. But I'm going to look a bit closer at this.
Permanent dual controls mounted inner fairing oposite cig lighter. With plugs coming out at the nose of the seat
That's a neat setup. I guess you'd have to sell it with the bike if you traded it although at my age this bike will probably outlast me anyhow! Maybe, after adding the liner, I might eventually look into it though. I'll see how often I use it first. Too bad you couldn't buy one with only one lead with two connections for the liner/gloves (separately controlled) - ie one plug-in. Having to hook up to two connections each time must be a pain.
I made up some leather panels that the controller mount,s too..If I can find the pictures I will post them..
I think I saw that on another post but don't think it had pics. I might be able to pick up a piece from a shoemaker to do something like that. My bike (2010 UC) has the heat shields. I'm wondering about putting a piece of velcro on the inside of the left one to give the clip on the pouch some grip and mounting it there. It would keep the wires away from my tank and help avoid scratching. Don't know if the heat would lift the velcro off. Thinking... thinking...
Yes, a controller is absolutely necessary. I took the same approach as you. Got the gloves first, and was somewhat disappointed. Mostly because of all the wires that are running all over the place. The next year I got the jacket liner. Makes all the difference in the world.
I have rode with temp as low as 3 degrees. With that heated gear and one extra layer, I was toasty warm taking an 80 mile interstate ride at full speed. And that was on my Sporty. Lots of other ways to help keep the wind off on a UC
That's my plan. I'm usually able to stay reasonably warm by dressing for the elements but my hands always get cold late in the year. Gloves were more of a priority.
Not much trouble considering I don't use it that often, look at my location. I shouldn't even be in this thread. lol
BTW Mine has a nice HD logo on the pouch
I did the same thing but ended up giving the Gerbing gear to my wife, works great for her as a passenger. Warm and Safe also sells excellent liners that have a built-in pocket for the remote controller should you decide to upgrade later. They're a bit more form fitting than the Gerbing as they don't have the knitted cuffs and waist so they're easy to tuck into your riding pants.
The plugs and the electrical requirements of the different brands of liners are identical. You can mix and match different brands of controllers with different brands of gear in most cases.
I very seldom run my liner or gloves at MAX so the idea of replacing a controller with an on/off switch as an earlier poster advised does not make a lot of sense to me. Your choices would be limited to too hot or too cold.
