Will someone explain the AFR numbers
Old Oct 2, 2011 | 02:34 PM
ClassicBill's Avatar
ClassicBill
My mechanic was telling me the other day that some tuners advance the timing too much trying for better numbers, then bikes have trouble with pinging. I'm not a tuner though, so all i know is what I'm told.
Old Oct 2, 2011 | 02:45 PM
Neggy ZRXOA 5248's Avatar
Neggy ZRXOA 5248
IMHO you want the bike tuned for 13:1 across the board.
Do you have a dyno available to sniff it ?
The bike night I go to has a dyno come in at least twice during our 18 week season. Best 25 bucks I spend is to have the bikes checked to verify any tuning I did over the winter was done right.
Right now it looks like my ZRX might be a tad rich, as I lost 3 hp when it was dyno'd at 70 degrees compared to 86 degrees 6 weeks ago.
Old Oct 2, 2011 | 02:54 PM
Shredding rubber's Avatar
Shredding rubber
Advanced timing will cause pinging however if it just happened all of a sudden I am more inclined to believing an 02 sensor failed or a sensor of some sort isn't adjusting the fuel mix properly. Does the tuner you have read and clear cel's. I would return the bike back to the stock tune and see if the problem persists.
Old Oct 2, 2011 | 03:34 PM
fabrik8r's Avatar
fabrik8r
Originally Posted by PLEIKU69
Thanks for all the great info guys.I do have a TTS tuner ,stage 2, no cat, t555tq cams and jackpot slipons.It has been dynoed and the afr runs about 13 to 13.5 but this weekend I started having major pinging and was just wondering if it was afr but apparently not.It also stalled a few times for no reason and a few hiccups back from the air cleaner and temp was below 220.I am now curious about CKP since I have had no problems previously and it pings at all temps and thru all gears .So any thoughts guys ?
You're not gonna like this either but a straight AFR across the board is a rookie tune or at least an easy money tune for the operator. Based on your symptoms, and description of the condition, at 13:1 you might have carbon build up that has raised your compression and reduced your resistance to detonation, just a possibility. Check cranking pressure and compare it to when the build was first done. Good luck, let us know what you find.
Old Oct 7, 2011 | 04:43 PM
PLEIKU69's Avatar
PLEIKU69
Ok guys thanks for all the input it was intake seals leaking ,replaced and all is well.
Old Oct 7, 2011 | 07:14 PM
kojak's Avatar
kojak
Default HD Fuel Injection Basics
There is a lot of confusion on this topic. Here is my attempt to simplify and explain and probably confuse as well! Ok, here goes....
The ECM is the brain of your fuel injection system and lives to control the amount of fuel being delivered at any time by the fuel injectors. It does that by referencing stored tables (maps) in its memory as well as the 9 different sensors that feed into its decision making process. Incase you are interested, these sensors are: Throttle Position Sensor, Manifold Absolute Pressure, Bank Angle Sensor, Intake Air Temperature, Engine Temperature, Vehicle Speed Sensor, Crank Position, Ion Sensing System, Idle Air Control
There are 3 tables that the ECM uses constantly, the VE tables (one for each cylinder), the AFR table and the Spark Advance table. I'll explain how these work in a sec.
There are other tables that are used in special conditions, the Cranking Fuel table, the Warm-up Enrichment table, the Idle Rpm table and the Intake Air table. The ECM knows to use these from the input from those 9 sensors i.e. when it detects really low rpms it knows you are cranking the engine and goes to that table.
So your engine is running and here is how it works. The ECM reads the VE tables constantly, using throttle position and rpm to know how much air is going through your engine. Then it uses the manifold pressure and intake air temp to understand how much oxygen is available for each cylinder. Then it goes to the AFR tables and based on load and rpm, reads the right AFR value and know how much fuel to inject to achieve that AFR. At the same time, the ECM reads the Spark Advance tables to send the signal to the coil.
The much talked about O2 sensors are a tail-end minor adjustment to the ECM in closed loop operations designed to maintain a 14.7 AFR that is considered complete combustion.
So the bottom line is, since the entire deal is based on the ECM knowing how much air is passing through your engine and the VE tables based on a set configuation (engine size, exhaust, throttle body size, air cleaner etc).....when you modify your setup beyond say slipons, you have to adjust your tables.
Old Oct 7, 2011 | 07:31 PM
speakerfritz's Avatar
speakerfritz
and then there's the buisness of physical head engine temp and air intake air temp. a lot going on for sure.
Old Oct 7, 2011 | 07:33 PM
'05Train's Avatar
'05Train
Lets start with the year of the bike we're talking about. If it's 2009 or older, we're talking AFR, if it's 2010 or newer we're talking Lambda.
Either way, no matter what you read on the internet, there is no such thing as the "right" AFR. Mine is all over the place, depending on load and RPM. So when you say that yours runs around 13~13.5, is that what your main table is showing in all the cells? If so, your tuner ripped you off. There is no reason whatsoever to run any richer than 14.4 or so at cruise. Keep the bike in closed loop for cruise, and you'll get better mileage. Fatten it up at WOT (I'm in the 12s there).
Old Oct 7, 2011 | 07:50 PM
harleytuner's Avatar
harleytuner
Here's a screen shot of what I set the AFR potion of the MAP to when I am done tuning a bike. This is a creen shot from super tuner, but the same holds true for TTS. The Red cells are were I leave the bike in closed loop, it will allow the ECM to make minor adjustments for you. You will notice as the RPM's and the load increase I have it set so the bike runs richer.
Long lonesome highwayman
Nov 18, 2018 08:29 PM
Dobe66
Aug 25, 2013 06:33 PM
car5car
Dec 8, 2009 09:44 AM
sleazy1369
Jul 22, 2008 08:07 AM
2007fxdc
May 22, 2008 12:38 AM
