Will someone explain the AFR numbers
HD runs a system that despite many critics actuall IMHO does a pretty good job bearing in mind the requirements placed on it by EPA.
Closed loop runs 14.6 : 1 which means by volume 14.6 parts air to 1 part fuel. This is excellent for economy as its about where therotically all the fuel is burnt.
For more performance, under load, and at start up it requires a richer mixture, i.e. less air to fuel. So 14.5 : 1 and down is richer and 14.7 : 1 and up is leaner.
Our air cooled engines run quite hot as compared to a water cooled engine, as the cooling system is less efficient. Running a richer mixture will to some degree make things run cooler but at the expense of mpg. As someone once said, "There is no such thing as a free lunch"
I run a pretty much stock 96" RK with AN BS air filter and free flowing pipes. I want good mpg over performance so run closed loop pretty much as HD designed it but have adjusted the CLB tables to help the heat just a little. I run about 14.5 : 1 in closed loop. Outside closed loop I have slightly altered some AFR settings and timing to eliminate knock, and improve power delivery.
I have adjusted the VE (volumetric efficiency) tables using the SERT software to cater for the modestly increased gas flow through my engine due to my modifications.
My bike runs good, and I am about to remove the stock headers for the Jackpot 2-1-2 stainless system, which I think will bring the heat down further.
I doubt I have helped much but at least I bumped the thread for you.
WB
Closed loop runs 14.7 : 1 which means by volume 14.7 parts air to 1 part fuel. This is excellent for economy as its about where therotically all the fuel is burnt.
For more performance, under load, and at start up it requires a richer mixture, i.e. less air to fuel. So 14.6 : 1 and down is richer and 14.8 : 1 and up is leaner.
WB
So, 14.7:1 is a hot running engine with less power potential and lower emissions which consumes less fuel
AND 13.5:1 is a cooler running engine with more power potential and higher emissions which consumes more fuel
