plug wire install on a '01 FLHRPI
Old Oct 4, 2011 | 11:51 AM
barryd1953's Avatar
barryd1953
Default plug wire install on a '01 FLHRPI
simple question. I am having trouble lifting my tank to install new plug wires. Has anybody got any suggestions?
Old Oct 4, 2011 | 05:03 PM
dawg's Avatar
dawg
What kind of trouble? Shouldn't have to do much more than lift the back up and put a piece of wood under it.
Old May 17, 2012 | 09:35 AM
barryd1953's Avatar
barryd1953
thanks. I thought I'd be draining gas lines to lift the tank.
Old May 17, 2012 | 09:51 AM
TheArchitect's Avatar
TheArchitect
I just swapped the plug wires on my SG, I had to disconnect the fuel line (really easy to do on the newer models) and unbolt the tank to lift it enough. I didn't remove the fuel crossover, but it was really tight getting my hands in there to plug the wires into the coil. It would have been a lot easier to just remove the tank. I learned my lesson and ordered a quick disconnect to install on the crossover line if/ when I ever need to remove the tank again.
Old May 17, 2012 | 11:30 AM
jcb1975@yahoo.com's Avatar
jcb1975@yahoo.com
Heres what I do;
Run the tank as low as you can. Get a short length of 5/16 fuel line, two hose clamps and two bolts that will fit into that line. Put one bolt in the end of the piece you have and clamp it down. I did this on the right side of my Ultra, lower fairings removed. Put towels down on front fender and stuffed as may as I could on top of motor and generally around that area to catch any spills. Take a set of vice grips and put some duct tape on the jaws to soften up the edges. Clamp that onto the fuel line opposite the side you will remove it from the tank. Remove line from tank with the other piece of fuel line ready to put on the tank. The piece you removed will trickle a little but not much because of the vice grips. After all is secured with those lines, remove the tank the rest of the way. Gives you a good chance to clean and wax the thing real good too. Just my $0.02
MIBPreacher
Mar 5, 2012 05:35 PM
strtarrow
Mar 3, 2011 07:59 PM
aviscomi
Jan 18, 2010 07:42 PM
cornishman
Aug 6, 2007 05:26 PM
bob53
May 7, 2007 12:04 PM
