tp rear speaker wiring routing
Old Oct 6, 2011 | 07:23 PM
FIREHAWK116's Avatar
FIREHAWK116
Default tp rear speaker wiring routing
I am running the rear speaker wiring on my 09 street glide. The harley instructions say to run the wiring under the tank console. It doesn't look like there is enough room. Is this right?
Also where do you put all wires from the in the fairing? Thanks
Old Oct 6, 2011 | 08:14 PM
Harleypingman's Avatar
Harleypingman
Haven't routed the tour pak speaker wiring, but I'm doing the HD saddlebag lid speakers, and those instructions say to remove the gas tank and route the wires in the harness tray under the tank. Interesting for essentially the same wires (rear speakers) that your instructions say to route them under the tank console, while the speaker lids go under the tank.
As for the wiring inside the fairing, you'll need to tuck the wiring in as best you can. Below and to the sides of the HK head unit works, and, if you can, along the top rear of the HK. There's very little room at the front of the HK radio or its front edge for storing excess wiring.
Carl
Old Oct 7, 2011 | 08:33 AM
FIREHAWK116
Thanks for the help Carl. I ended up pulling the tank and routed the wires in the plastic tray. I ran the interconnect harness next to the main harness up and over the radio. Maybe the instructions are for the older style fuel tanks?
Old Oct 7, 2011 | 08:45 AM
Harleypingman
You're welcome; glad you got the wires installed.
If you can, post the "J" number of the installation instructions. I'll be adding tour pak speakers this winter and would like to see those instructions even though I'll be using aftermarket speakers and tour pak pods.
Carl
slodsm
Audio Systems
Oct 31, 2018 09:36 AM
PostalRoadKing
Audio Systems
May 31, 2017 09:02 PM
weekendwarrior
Mar 13, 2011 01:28 PM
SOLOLUCKY
Oct 14, 2009 08:40 PM
89FLHT
Sep 10, 2008 12:42 PM
