SE Compensator
Old Oct 12, 2011 | 12:15 PM
itsmf's Avatar
itsmf
Default SE Compensator
On a 2009 Ultra,is it possible to install said comp. backwards and run for 15,000 miles before the nut works loose?
Old Oct 12, 2011 | 12:31 PM
Lowcountry Joe's Avatar
Lowcountry Joe
Are you saying you have a loose nut?
Old Oct 12, 2011 | 12:34 PM
harleycharlie1992's Avatar
harleycharlie1992
Unofficial HDF Chaplain
just behind the handlebars!! just kidding!!
I can't see how you could put it in backwards in the first place. what is supposed to be wrong? (besides the nut coming loose?) Sounds like the nut just came loose, and did whatever damage it will do
Old Oct 12, 2011 | 12:39 PM
itsmf's Avatar
itsmf
Default SE Comp
Yes,the nut did come loose and damaged the sprocket.
Old Oct 12, 2011 | 12:49 PM
harleycharlie1992
well you most likely need a new compensator,just have to go and buy another one, follow the instructions closely,use red locktite, and get on down that road!! sorry to hear that for ya
Old Oct 12, 2011 | 01:14 PM
EasternSP's Avatar
EasternSP
There's not a lot of room for it to come loose before it starts tearing up your outer primary. I just can't picture how any part of it could have been installed backwards.
Old Oct 12, 2011 | 01:19 PM
bagman1's Avatar
bagman1
He probably means the springs were not installed properly.
Old Oct 12, 2011 | 01:22 PM
harleycharlie1992
I guess that could be, but it seems it would have been giving vibrations, and or clunking well before the 15k mark
Old Oct 12, 2011 | 03:50 PM
V2Evo96's Avatar
V2Evo96
Maybe the OP means that the compensator fastener screw came loose, and he presumes the cause may be because the comp wasn't installed properly?
Which is true cuz if the comp was installed properly the screw wouldn't come loose.
Old Oct 12, 2011 | 05:14 PM
fathertime's Avatar
fathertime
From: CHILLIWACK B.C CANADA: have a u.s shipping adress
Default s.e comp
just did mine a few weeks ago.. the only thing that could possibly be installed incorrectly would be the springs and you would know it rite away..you would have a bunch of slack and a real bang in the primary..i think it would be obvious rt away...as for the bolt comming loose , did you torque to 100 lbs, slack off and retorque to 150 lbs?..the bolt has loctite on it from the factory...
