Starter doesn't engage
Old Oct 17, 2011 | 07:26 PM
customsoftail200's Avatar
customsoftail200
Default Starter doesn't engage
This past weekend my starter was giving me trouble and now it doesn't engage at all. I took the primary cover off, the jack shaft comes out and engages the clutch gear bu it doesn't turn it. I hear the electric motor spinning but no movement. I then took the starter out of the bike and started disassembling, I have it apart and have the gears out but I don't see anything wrong. Any ideas???
Old Oct 17, 2011 | 08:00 PM
JDB's Avatar
JDB
Is your battery good.
Old Oct 17, 2011 | 08:37 PM
z71_fourwheelin's Avatar
z71_fourwheelin
Had this happen to a friends bike, he needed his starter rebuilt. But make sure you have good voltage first.
Old Oct 17, 2011 | 08:41 PM
Lonewolf176's Avatar
Lonewolf176
Starter clutch.
Old Oct 17, 2011 | 08:47 PM
smithbrl's Avatar
smithbrl
I know practically nothing about a starter clutch but if the gear is engaging and the motor is spinning, I'd think the clutch was slipping.
Lowcountry Joe's Avatar
Lowcountry Joe
Can you hook up the starter to a battery in the garage just to see whether or not it works?
Old Oct 17, 2011 | 08:48 PM
smithbrl's Avatar
smithbrl
Originally Posted by Lonewolf176
Starter clutch.
I guess I type too slow. lol
Old Oct 17, 2011 | 09:01 PM
customsoftail200
Battery is good, voltage fine. Sounds like it may be a clutch if the motor spins but I get no output. Are clutches available separately or do I need a new starter?
Old Oct 17, 2011 | 09:05 PM
dawg's Avatar
dawg
If you go the HD route, 31516-94A $113. Can also get a Nippondenso for a 1998 Toyota Camry. Same thing.
Old Oct 17, 2011 | 09:07 PM
soft 02's Avatar
soft 02
+1 on a starter clutch!
