Starter doesn't engage
Old Oct 17, 2011 | 09:09 PM
customsoftail200's Avatar
customsoftail200
Thanks Dawg, those part numbers are for the clutches?
Old Oct 17, 2011 | 09:15 PM
dawg's Avatar
dawg
Yes, starter clutch
Old Oct 17, 2011 | 09:29 PM
checkers's Avatar
checkers
This past weekend my starter was giving me trouble and now it doesn't engage at all. I took the primary cover off, the jack shaft comes out and engages the clutch gear bu it doesn't turn it. I hear the electric motor spinning but no movement. I then took the starter out of the bike and started disassembling, I have it apart and have the gears out but I don't see anything wrong. Any ideas???
I would have cleaned and tighten battery cables first, common problem and your symptons
Old Oct 18, 2011 | 04:06 AM
grbrown's Avatar
grbrown
That's a good idea, but his starter clutch has gone! Mine has too in the last couple of weeks. My starter is over 20 years old, so I may well replace the whole thing, but customsoftail200's bike is much newer. I would dismantle the starter and clean it up inside, make sure all is fine, and fit a new clutch. They are available on Ebay.
Old Oct 18, 2011 | 10:33 AM
customsoftail200
Is it common for these clutches to go? I do have a higher compression 95" in it
Old Oct 18, 2011 | 10:44 AM
grbrown's Avatar
grbrown
They are readily available, which might suggest they do, but in over 20 years mine has packed up twice. However that is an early Evo starter, not as high power or robust as later bikes like yours. Also mine has done many years service with a tuned stroker, now an S&S 107", so I reckon it has probably earned retirement!
There are 1.4kW and 1.7kW starters available, that are alternatives I am considering. It's worth checking what power rating yours is and upgrading.
thenewrage's Avatar
thenewrage
Do you have manual compression releases ?
Old Oct 18, 2011 | 04:06 PM
customsoftail200
Yes I have manual compression releases. I always use them when the engine is warm but I am going to start using them all the time.. I dropped the starter off to our local starter/alternator rebuilder today, he said it should be all set tomorrow. I would've done it myself but I had to go there to show him the clutch so he could order the right one. He said he would lube it all up and put it back together so I said why not.
mballard
Shovelhead
31
Jun 6, 2019 08:01 PM
lebert
Aug 7, 2010 07:03 AM
rmxlr
Aug 31, 2007 08:14 PM
02glide
Oct 26, 2006 01:00 AM
Joker441
Shovelhead
Feb 8, 2006 04:56 AM
