How do you adjust the speedo?
Old Oct 22, 2011 | 04:45 PM
Ham____'s Avatar
Ham____
Default Read you answer
Originally Posted by Mighty Nation
Adjusting the speedo is easy, you just poke you finder in there and run it around the waist band. Don't get caught wearing them in public. Hope that helps.
Read your answer and I am still laughing---too good!!
Old Oct 22, 2011 | 04:54 PM
balcy24's Avatar
balcy24
Originally Posted by RaceFace
Yeah, I had to read it 3 times to realize he meant FINGER!! LOL!!! I'm slooooow tonight!
If it is cold enough outside, he may have meant finder!
Old Oct 22, 2011 | 07:42 PM
Uncle Larry's Avatar
Uncle Larry
Adjusting the speedo is easy, you just poke you finger in there and run it around the waist band. Don't get caught wearing them in public. Hope that helps.
I just spit my beer all over the damn screen !!
Old Oct 22, 2011 | 07:59 PM
103 sedona orange's Avatar
103 sedona orange
faster is better.
Old Oct 23, 2011 | 08:18 AM
FBFletch's Avatar
FBFletch
As someone already pointed out, changing your cams does not effect the speedometer. Additionally, vehicle manufacturers (both auto and motorcycle) intentionally calibrate their speedometers from the factory to read higher than actually (some more than others). It's a liability issue. If you were to get a speeding ticket because the speedometer was reading too low, then you could take the manufacturer to court and say it was their fault.
ANYWAY, if you find it bothersome, you can installed a speedometer calibration kit. After my six-speed gear set install, my speedometer read about 15 mph low. My local HD dealership install a SIM-1 kit from Dakota Digital (which someone already mentioned):
http://www.dakotadigital.com/index.c...cat/cat115.htm
Now, here's the rub. The way you calibrate it is, after install, you follow someone down the road who is going a steady speed and use the up and down arrows on the SIM-1 to calibrate your speedometer while it is in motion. However, since the vehicle you're following has a speedometer that's been calibrated to read higher than actual, you probably aren't going to notice a difference between it's speed and your own.
Hope this helps.
Old Oct 23, 2011 | 10:32 AM
T_om's Avatar
T_om
Hope this helps.
If the other bike is using a GPS instead of the Harley "Guesstometer", you will be spot on. I would never trust another bike's speedometer.
Tom
Old Oct 24, 2011 | 05:44 AM
FBFletch's Avatar
FBFletch
Tom
Good call. But, it depends on the update rate for the speed indication on the GPS. If the GPS updates the speed every second or every couple of seconds it could be used. My Garmin (which is an older one) doesn't seem to update the speed frequently enough to be used for a calibration. I suppose if I found a long flat stretch of road, set the cruise control on the vehicle with GPS, and got a couple of consecutive speed updates that were the same it could be used as a standard for calibration.
Old Oct 24, 2011 | 05:59 AM
MNPGRider's Avatar
MNPGRider
I posted a chart back in post # 6. Find a flat stretch of state highway and use the mile markers. Hold your speed steady, and time yourself between markers, and compare to the chart. Adjust accordingly. You can double check your settings when you come across one of those electronic signs that tells you your speed.
Old Oct 24, 2011 | 06:42 AM
Jim Dawson's Avatar
Jim Dawson
My TTS Mastertune lets me change the speedometer calibration. Mine is exactly on with my GPS.
samhallnc
Aug 6, 2018 08:39 AM
nomad billy
The Dark Side
Apr 26, 2016 03:42 PM
Foxster
Apr 11, 2011 01:50 PM
DECON BLUE
Jan 3, 2009 09:16 AM
techmed
May 21, 2008 04:44 PM
