Can I put a closed loop programer on a 1999?
Old Oct 21, 2011 | 10:33 PM
Sputter's Avatar
Sputter
Default Can I put a closed loop programer on a 1999?
Hello-
Well weather is cooling off here in IL, so starting to plan out winter projects etc. I'm still tearing down for a complete repaint and probably some body work mod's. I'm still looking at a possible cam change (again) and head work, with new exhaust. Wondering if I replaced the MM injection system with the 'thundermax' injection system, and installed 02 sensors in the new ehaust could I also then do the closed loop monitoring system for live on the fly tuning?
thanks for the help
Old Oct 21, 2011 | 11:11 PM
131tman's Avatar
131tman
ThunderMAX 50mm EFI-Marelli Conversion Kit & Auto Tune Module $2200+
Big Bore kit, gear drive cams, headwork, exhaust $2000+
Old Oct 22, 2011 | 12:09 PM
Sputter's Avatar
Sputter
Thanks Tman- I have been researching the thundermax kit, what I"m unsure about is the live tuning box they have. Since my 99 doesn't have 02 sensors currently, I"m wondering if I have bungs welded into my header, could I use one of the closed loop fuel management systems?
Old Dec 2, 2011 | 10:15 PM
ThaGlyde's Avatar
ThaGlyde
yes you would have to get the bungs welded
Old Dec 2, 2011 | 11:42 PM
mkguitar's Avatar
mkguitar
cost benefit isn't there.
If you are looking at "reliability issues" or need tuning flexibility wouldn't a carb be better?
- and I'm not a complete dinosaur- I use o2 sensors to tune my carbed bikes, even the panhead
I looked into efi kits for my evo bagger and my old Cadillacs- and found that cost way too high for what they were, most set ups were a throttle body type injector
mike
LazyLion
11
May 9, 2021 10:26 AM
yzergod
Sep 16, 2013 10:25 AM
Papamte
Dec 5, 2011 06:04 AM
N-gin
18
Mar 30, 2010 01:00 PM
LazyLion
Exhaust System Topics
Dec 5, 2007 03:33 PM
