Need Help with Twin Cam Heads
Old Oct 22, 2011 | 08:10 PM
z71_fourwheelin's Avatar
z71_fourwheelin
Default Need Help with Twin Cam Heads
Im tryin to remove my heads for a big bore kit and it is not coming undone. Anyone with direct knowledge please PM me If you can talk on the phone and help. Thanks
Old Oct 22, 2011 | 08:37 PM
z71_fourwheelin
Bump!!
Old Oct 22, 2011 | 08:40 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Did you take the 4 head bolts out?
Drew
Old Oct 22, 2011 | 08:45 PM
z71_fourwheelin
yeah I got the four bolts out.. My manual is missing that page of removal... go figure. But i read something about the 2 bolts holding the breather in the center of the rocker plate and it just cam off. So thanks for your help.
Old Oct 23, 2011 | 12:21 AM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Buy the shop manual for your bike and get the Metric Hammer out.
Old Oct 23, 2011 | 12:44 AM
speakerfritz's Avatar
speakerfritz
great to hear that you got it. I'm doing a 103 upgrade soon and intend to post so folks can point out potential issues. I'll probally get a lot of tips that I already know, but would probally also get some info I didnt'. Make sure you check your ring end gap as well as you valve to piston clearence. If your going forged pistons need to check your side gaps. if you had your jugs bored, need to get all the diamond dust out. If your going to also do a stage II, you'll need cam shims and highly recommend cam inner bearing replacement. If you doing a cam change to 255's, some -07 cams have the alignment dot in the wrong place. if you have side to side rocker shaft play, there are shims for that as well. Might also want to think about MCR's. There's a guy on ebay that does them for 125 a apair which includes MCR's and shipping back to you.
Old Oct 23, 2011 | 02:17 AM
michael427's Avatar
michael427
be sure you follow the order and torque sequences and all that important stuff too. It does make a difference. once you have the bottom rocker box half off take out the 4 head bolts and the head comes right off.
Old Oct 23, 2011 | 08:52 AM
fabrik8r's Avatar
fabrik8r
Sometimes you gotte smack 'em with a dead blow to release the gasket seal.
Old Oct 24, 2011 | 08:21 AM
z71_fourwheelin
What I was missing was the 2 breather bolts in the middle of the rocker box. Thanks everyone.
Old Oct 24, 2011 | 12:07 PM
djl's Avatar
djl
No, you just needed to smack the head like fabrik8tr said. The only bolts holding the head on are the four head bolts; think about it.
