Cometic .030 head gasket
Old Oct 24, 2011 | 04:08 PM
Biggzed's Avatar
Biggzed
Originally Posted by johnd5412
Zach,
So w/out the head gasket installed and the piston at TDC I should get a feeler gauge readout of 0 to 0.005. If my piston while at TDC is greater than zero then I can assume that a .030 head gasket would cause piston to valve clearance problems?
You got it!
If your piston is above the cylinder at TDC, there would still be a chance the valves would clear, but it is still too tight of a squish band for a street motor (assuming the .030 hg).
BTW - For about $40 iirc, Cometic will make you a set of MLS head gaskets in any thickness. My HQ kit came with .027" gaskets, and my pistons are down the hole .005".
Zach
Old Oct 24, 2011 | 04:57 PM
whistlebritches's Avatar
whistlebritches
i love Cometic
Old Oct 24, 2011 | 08:58 PM
johnd5412's Avatar
johnd5412
Thanks Zach...great info!
Old Oct 24, 2011 | 09:50 PM
redrubicon2004's Avatar
redrubicon2004
Zach,
Deck height and piston to valve clearance are really two different things all together. You could have a -.010 deck height and still have piston to valve clearance issues with a .040 head gasket depending on your piston and cam selection.
Piston to valve clearance should be checked either way.
If you bought all this from Fuel Moto as a package, I would talk to them about it. If it is a combo they put together often, they might tell you that you dont need to check the clearance. They might know that it has more than enough clearance.
Old Oct 26, 2011 | 06:55 PM
Mike's Avatar
Mike
A squish check is different that a valve clearance check. You should always do a squish check if you're building a high performance motor. Too tight squish can result in piston to head interference.
Checking valve clearance is something that need to be done when you're using cams with a lot of TDC lift, and when your'e running oversize valves in certain configurations. If in doubt, check it.
Two great pages on checking squish and checking piston to valve clearance can be found on the NRHS website. The instructions are easily understood, and they've got some good pictures, too. Highly recommended.
Checking Squish
SportbikeCO
Engine Mechanical Topics
16
Mar 6, 2017 09:44 AM
speakerfritz
Oct 5, 2011 06:25 PM
cjlandry
Exhaust System Topics
Jun 5, 2011 07:10 PM
Russbucket
Jun 15, 2010 08:33 AM
bdaug50
Mar 8, 2008 12:54 AM
